Question about Roper REX4634KQ Electric Dryer
My dryer belt is broken - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Aug 21, 2010
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
Hotpoint dryer won't stay on
The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
Apr 27, 2013 | Dryers
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
My dryer turns on but does not turn the tumbler AROUND
Check belt & belt tensioner. Belt could be broken or tensioner spring broke releaving tension around motor pulley. You can do this by removing access panel on back of dryer, make sure you UNPLUG dryer before you do anything. Broken belt requires removing front drum end, not so easy, but do-able
Feb 13, 2011 | Maytag Dryers
Broken belt for clothes dryer LG
Remove the front panel .. two screws probably.
Look for the belt tensioner on the floor when you get it open.
Mar 28, 2010 | Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Dryer runs belt not broken and tumbler doesn't spin
the belt may not be broken but it might be stretched past its limits check and see if the electric motor is spinning when the belt is off but my personal suggestion is take a digital picture of the belt on the pulley and tensioner so you can reference it when putting it back together
Apr 13, 2009 | Dryers
Stopped tumbling
First make sure your belt is broken.
Take a putty knife or a old CD and insert it between the top and the front panel about 2 inches in from the sides where the top and front come together.
Push the clips towards the back of the machine while pulling up on the top.
Once it is open you can tell if the belt is broken or not.
It you see no belt around the drum it is broken.
If you see a belt around the drum pull on it carefully.
If it does not come loose it is not broken.
After you do this, let me know the result.
We will then move on to step #2.
Mar 15, 2009 | Maytag PYE2200 Dryer
Dryer will not turn on
most of the dryer when the belt break the dryer will no longer run open the door manually turn the barrel if it moves frely the belt is broken there is a switch connected under the belt tensioner causing the machine not to start if the belt is broken thanks from gilles
Mar 14, 2009 | Dryers
Roper REX4634KQ Electric Dryer Logo
47 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
