I bought the ac with no manual...cant clear delay or other issue and set temp properly...it continues to change temps. ge ac with remote control aew12anw1
  • 958 Answers
SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Posted on Jun 24, 2008
  • 85 Answers
SOURCE: ac/heating unit not working properly.
Check your filters, make sure they are not dirty. Make sure your outdoor sensor is working properly. If it is then check the setting on the defrost timer. If you don't know how, you'll have to call an expert to come fix it. Diagnostic fees generally are around 65 to 125 depending on time and contractor.
Posted on Dec 06, 2008
leroyal
  • 2120 Answers
SOURCE: Haier AC
Open the front cover or take it off, make sure that the brass tubing is 1/8" away from the coil fins at it's entire length.
Posted on Dec 30, 2008
  • 146 Answers
SOURCE: I NEED THE INSTRUCTION MANUAL
http://www.fujitsugeneral.com/owners_manuals.htm
Posted on Jan 19, 2009
SOURCE: Thermostat unit not cooling house.
Okay. Here's what I suspect in order of probability:
- low refrigerant charge
- contactor not getting 24 volts from controller (controller problem)
- bad contactor
- bad capcitor
I'd start with the charge, as suggested by mastatech. But if it is low, you'll need a service call, anyway, so pressing the needle valve may not be necessary.
I'm assuming you're not going to be taking the unit apart and testing stuff, so you'd need a service call for that as well.
I guess bottom line is, call for service. At least, I think we've ruled out simple stuff which will avoid paying for a service tech to come out and flip a switch.
Maybe mastatech has some other recommendations.
Posted on May 10, 2009
Haier AC changing temperature by itself
Have you tried calling the manufacturer? If you need more questions for your Air Conditioning Repair needs, check us out online
Jul 05, 2017 | Haier Heating & Cooling
Does anyone know what's going on?
Unfortunately the bandwidths of remotes often crossover. You can put tape over the ir sensor on the ac.
May 21, 2012 | Haier Heating & Cooling
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
Aug 23, 2011 | Ovens
Lg split ac not working thro remote,it is working in manual mode only,i couldnt set the temp.now it is in 22degree temp.what is the solution please tell the problem
i have a similar situation going on this is the second time this is happening the remtoe sensor doesnt work when faced towards the ac .its really sad that i bought this unit just 5 yrs back
Sep 22, 2010 | LG LSC121PMA Split System Air Conditioner
I have a 95 Gran AM GT with 3.1 auto. The motor will run until it gets overheated and boils over, but the fan will not start.I have totally flushed the system,pulled and inspected the water pump, changed...
Fan operates when coolant temp reaches 226 deg.F and shuts off at 219eg.F
fan is controlled by the PCM infuts from Eng. coolent temp. sensor & Intake air temp. sensor
the yellow wire is the 5V reference and the black wire the is the PCM ground sensor
make sure your not using teflon tape on the threads of the temp sensor.
it sounds like the PCM wont turn it on. check the harness for continuity between temp. sensor and PCM harness
clear connecter - pin 17 black, pin 31 yellow
Sep 12, 2010 | Pontiac Grand Am Cars & Trucks
My remote will only turn the AC and now the temp goes to 85 degre
adjust your temp set point on the remote if is not working change the remote
Aug 21, 2009 | GE ASM12AK 12,300 BTU Room Air Conditioner...
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
AC thermostat does not control AC. AC runs continuously. Have to shut system off to stop AC.
are you using the old coventional thermostat? using mercury
or was it digital?
chances are the reason it is not stopping because it can not detect the right temp inside your house, if you have set this for example 74F AC would run continouisly until it reaches that right temp, until that time, it would surely not stop,
check for any windows, door that might cause some air leaks inside your house for a start, close all exhaust fan and see if you can see any difference, if not this might be the right time to change for a digital temp control, it not that expensive and easy to install
Jul 25, 2008 | Heating & Cooling
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
