Question about GE JBP90 Electric Kitchen Range
When oven is turned on it cuts off after a couple of minutes, smells like something is burning, and shows Fs on the LCD screen
  • 139 Answers
Sounds like your bake element is ready to burn out .or already has if its not getting red its out look at element for any abnomalitys like the coating should look the same from start an stop of element
Posted on Aug 22, 2010
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
I have a Bosch 1617 EVS router, a couple of years old, one of several routers, so not a lot of hours on it. A minute or so after turning it on I get a burning smell. It doesn't smell when I run
Check the armature bearings, especially the lower one hear the collet. It's possible some of the liquid wrench got into the bearing and cleaned out the lubricating grease that's in there. If the bearing is dry or damaged, either from use or during the removal of the stuck collet it will cause the motor to work harder which causes heat buildup and eventually a burning smell. If you bent anything you would feel a very distinct vibration in the tool when you turned it on that wouldn't have been there before. The bigger the bend the greater the vibration.
Sep 19, 2012 | Bosch 1617EVS Router
Error code -FS- on display with 3 long beeps
Hello :
Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds you need to replace humidity sensor .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Car smell burned rubber idle or moving after a couple of minutes running
Are you saying " car smells like burning rubber"
I would say something has fallen down onto either your exahust pipe of exhaust manifold, possibly a hose or wire, you need to find out before something shorts out.
Feb 07, 2010 | 2003 Chevrolet Impala
I have a general electric microwave it works but will not heat food and when i turn it on it smells like something is burning
  1. inspect plastic coupling beneath tray.
  2. Check ring and roller assembly for misalignment or debris.
  3. Make sure that tray is sitting properly on turning mechanism.
  4. If carousel motor is broken, contact a service technician.
    hope this helps you
Dec 30, 2009 | General Electric Microwave Oven
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
Screen goes black, still have audio
I first changed the 220uf capacitor with no luck. I flipped the BURN switch to on and the set has been working great for a week now. Daughter left it on for about 20 hours overnight with no problem. Anybody have an idea what those 4 tiny switches are for? I have heard these type of switches called "dip switches". They are tiny white switches in a yellow block on the lower left side of the upper circuit board. The top one was labled 40", the next one down was labled 46", the 3rd one was 4 letters "EW" something I think, and then the bottom one was labled "BURN".
Jun 22, 2009 | Polaroid FLM-4201 42 in. LCD Television
Smell of burning in my daewoo microwave oven. It has never been used before
Daewoo make some cheap microwave ovens. I have one, and it is rubbish. It came fitted in a new caravan, and because it decided to keep cutting out after only a few minutes of use, it was replaced by another that had the same problem. I know it's a cheap oven, but it should work. I wouldn't recommend this to any caravanners, and would recommend a different make.
The smell should go when the Daewoo goes!!
May 03, 2009 | Microwave Ovens
Microwave light
my kenmore microwave model # 66222, doesn't let the steam out, its ventilated so I know thats not the problem, smells like its burning then shuts off and doesn't come back on until its cooled off, this happened when cooking a Baked Potato, also when I cook something for over 5 minutes
Aug 13, 2008 | Microwave Ovens
GE JBP90 Electric Kitchen Range Logo
137 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
