Question about Avaya Corded Phone avaparp18d
I would like to turn off the ringer on this phone for incoming calls.
    President:
  • Avaya Master
  • 860 Answers
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Posted on Aug 21, 2010
5 Suggested Answers
  • 201 Answers
SOURCE: simply want to turn ringer off at my phone for external incoming calls
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Posted on Nov 12, 2007
Just_Bobz
  • 448 Answers
SOURCE: I have a vodavi phone system and am trying to turn
Break into admin section of voicemail, go to system greetings, select greeting you wish to change. Need more info, email. If this is helpful, please post as such
Posted on Apr 11, 2009
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
  • 6 Answers
SOURCE: INNOVAGE 1604007
Press SET. Press UP to select Set 8 Speech. Press Set again to confirm. Screen will show default setting SPEECH ON. press Up or DOWN to select ON/OFF. Press SET to confirm newetting
Posted on Dec 30, 2009
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 | Cell Phones
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Feb 12, 2009 | NorStar Meridian M7310 Phone
Volume off on incoming calls
There are two ways 1) as your looking at your phone on the top left side of the unit there is an little toggle switch to turn the ringer of or down just a bit. 2) (navagator key) in the bottom right hand corner there is a circle with four arrows on it simply press the down arrow until it says ringer off
Jan 07, 2009 | Panasonic KX-T7730 Corded Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
No ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Mar 30, 2008 | Panasonic KX-TG6052B Phone
Simply want to turn ringer off at my phone for external incoming calls
Nov 08, 2007 | NorStar T7316E Corded Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Avaya Corded Phone avaparp18d Logo
4,864 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
