Question about Mitsubishi WD-52825 52" Rear Projection HDTV
TIMER BLINKING RED
HI I HAVE A WD-62825 TV , IT WAS GIVEN TO ME BAY A FRIEND BECAUSE THE TV WOULD NOT COME ON AND THE TIMER LIGHT IS BLIKING RED , HE WENT OUT AND BOUGHT A NEW ONE AND I KEPT THIS FOR ME TO SEE IF I CAN FIX IT, DOES ANY BODY KNOWS WHAT TDOES THIS MEANS AND HOW CAN I FIX IT.
  • FIDO2527 May 03, 2008
    PLEASE ANY HELP WILL BE GREATLY APRICIATED.
Wd 52825 same thing-if you call mitsubishi enough they will fix it but you need a repair order from an authorized dealer and proof of purchase. happened to me.
Posted on May 12, 2008
  • Mitsubishi Master
  • 8,617 Answers
That set is plaqued with bad capacitors on the PWB, FMT and DM doards. Usually all problems assosciated with that model can be attributed to those capacitors. You can purchase a service manual that they will email you at the following link, and they will provide free tech support to help you straighten it out. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 03, 2008
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62825 Green Blinking light and TV won't turn on
I have the same problem with the green light blinking and the T.V will not come on. I have reset it and unplugged it and everything and still nothing. Can anyone help me
Aug 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-62825 TIMER BLINKING CONTANTLY
did you replace the two 3300uf caps on the PWB? how about the thermal sensor?
May 18, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Green timer light
check the number of blinks each blink means something
Apr 19, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Oct 29, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52825 52" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
