Question about Whirlpool Dishwashers
Whirlpool gu1200xtlt3 not cleaning, bottom of tub dirty after wash, not all soap dispensed
  • 213 Answers
SOURCE: dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Posted on Nov 21, 2007
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 423 Answers
SOURCE: my whirlpool dishwasher soap dispenser is
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Posted on Apr 18, 2009
  • 677 Answers
SOURCE: Soap is left in dispenser, not enough water? dishes are still dirty
www.dishwasherfilter.com has a product out that will solve this immediately. check it out.
Posted on Jul 26, 2009
heatman101
  • 43501 Answers
SOURCE: Our Whirlpool ADP5966 is not
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jan 25, 2011
How do I fix a whirlpool model number WFW9050XW00 soap dispenser overflowing water and not going into the tub?
Whirlpool WFW9050XW01 Use Care Manual Page 12
Sounds like the line between the soap dispenser and the tub is clogged. If you look at page 12 of the link I provided, it will show you how to remove the dispenser tray. Check, with a flash light and see if there is any obstruction. You can use a small flexible plastic snake to clear any obstruction.
Good luck.
Semper Fi,
Z
Aug 03, 2017 | Whirlpool Washing Machines
Water is leaking out the soap dispenser.
Remove the soap dispenser and clean it throughly, next check the tube from dispenser to the tub to be sure it is clear of blockage. Run the washer with hot water to clear any residual buildup that may be left in it.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LEFTOVERS ARE STILL BEING LEFT AFTER THE CYCLE IS DONE. I RINSE DISHES BEFORE HAND BUT THERE IS A BLACK DISCHARGE ON THE BOTTOM OF THE TUB, AND SOAP STILL LEFT IN DISPENSER.
clean detergent dispenser drain hose could be kinked,check pump it could be dirty,is the water hot enough and is the detergent new?to remove spray arm un screw spray tower also clean out spray arm there may be food particles in arm as well as tower,try this out try washing unit with out dishes sometime vinegar or c.l.r will take care of problem but let it soak and don't add detergent.thanks
Dec 01, 2009 | Kenmore 24 in. 16362 / 16364 / 16369...
Water is coming out of the soap dispenser
Hose from the dispenser to the tub is blocked , remove dispenser drawer and use a nylon bristle brush to clean it out
You will need a torch
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do i clean the Whirlpool Gold american collection top loading washing machine? I can see no filter to remove and the inside of the tub is getting dirty. The holes inside the tub at the top seem to be...
Dumped even more HOT HOT HOT water while poking around inside dispenser. Softener dispenser suddenly became unclogged and water began running out of the opening showing me that the dispenser was indeed clogged with softener buildup.
Sep 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
Apr 17, 2009 | Dishwashers
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool leaking water thru soap dispenser when off.
remove dispenser and clean next ck tube from dispenser to tub be sure it is clear
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap leaking out of the bottom of washer
highly likely if you didn't use your shipping bolts when moving your tub cracked bottom of soap dispenser inside of washer buy warrnnty sear about 250.00."less soap plz"
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My soap dispenser does not open properly and soap streaks on my door and detergent is always left over in tub no dishes are cleaned any suggestions?
ck water level ..i assume you mean diswasher water should be almost to bottom of float..if water ok are you sure main wash motor working
Aug 04, 2008 | Maytag Washing Machines
Dishwashers Logo
104 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
