Question about Mitsubishi WD-Y65 65" HDTV
How do I replace the bulb in my Mitsubishi WD-Y65?
  • 1,476 Answers
Hofferberr,
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to change the lamp, why when to change the lamp and where to get the best lamp at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Aug 21, 2010
How do I view movies in 3D on the Mitsubishi WD-Y65?
WD-Y65 is NOT a 3D ready TV. You either have to change the TV to see the movie in 3D, or just watch it in 2D in you current TV.
I have the same TV as yours. Current I connect a desktop PC to the TV via DVI port, and I watch Avatar using colorcode 3D(Amber/Blue) with Stereoscopic Player from www.3dtv.at It might be a way for you to enjoy 3D without change the whole thing, but it's an entire different topic.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Im trying to replace the bulb on my friends tv tonight, we removed the access panel and removed the old bulb but there seems to be another lens that shines into the bulb that emits from the side and we are...
What are you talking about? Just replace the lamp, if that does not solve the problem, also replace the thermal sensor. Nothing else. If you've damaged anything, take it to a repair shop. We are Mitsubishi authorized.
Jan 18, 2011 | Mitsubishi WD-Y65 65" HDTV
How to replace the bulb?
check in the back of the set is a 4" cover with 2 screws the lamp has 2 screws is easy to replace.
Dec 18, 2010 | Mitsubishi WD-Y65 65" HDTV
Wd-y65 dlp, have sound, no picture, tv shuts down after about 30 seconds. tryed tv reset 3 times,did nothing
sounds like you need a new bulb, mine is doing the same and the lamp light is coming on.
Nov 01, 2010 | Mitsubishi WD-Y65 65" HDTV
How to replace a bulb in a Mitsubishi WDY65
If your TV uses a bulb - there will be a access panel on the rear of the TV. Remove the panel to pull out the lamp cage.
Feb 20, 2010 | Mitsubishi WD-Y65 65" HDTV
Hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
Feb 14, 2009 | Mitsubishi WD-Y65 65" HDTV
Mitsubishi WD-Y65 65" HDTV Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
