Question about Gold Lantern GPS
Hi, The power cord to my SuperTalk II windshield visor-mounted Bluetooth device broke. The round case that ends in the tip that you insert into your car's cigarette lighter cracked and the metal tip is gone. I would like to replace the power cord. The SuperTalk II itself is fine. Please tell me how I can replace the power cord. Many thanks. Regards, -- Dan
  • 12,061 Answers
OK, well it's pretty easy really inside the thing that plugs into the cigarette lighter there are two wires, plus Red & Minus Black. Now that metal tip is POSITIVE and the other wire is negative, or earth.
You could simply go to say radio shack, or similar, and get a another 12 V male cigarette plug, and solder it on, or, you could get another already wired lead, and splice them together. As said there are only two wires and they should simply go color to color. Or if they don't match, then simply wire Plus to the Plus and negative to negative. There you go, your up and running again.
Posted on Aug 20, 2010
Drivers side visor snapped and radio stopped working ????
The antenna is a wire mounted inside the visor. If you don't want to put in a new visor, you can remove the wire and attach it to your headliner or at the top of your windshield.
Nov 01, 2010 | 1999 Dodge Durango
How do remove driver side sun visor
My driver's side visor inexplicably fell out the other day and I had to re-install it.
The metal frame has two openings in close proximity for the visor mounting. One is triangular and the other is a hole.
The teardrop portion of the visor has a post which fits into the above mentioned hole. The visor arm is attached to a piece which has three plastic lugs.
There is an opening visible in the last photo from the OP. I used a flat tip screwdriver and pressed IN on the tab inside the opening. This "dis-connects" the two pieces and allows the teardrop portion and the triangular lugs to move separately.
So, to install visor, press the tab, release the two portions, align the post with the hole and turn visor until three lugs line up with the points of the triangle. Push assembly flush with headliner and move visor back and forth until you hear a "click" and the two pieces are connected again. When I did it the click came when I moved the visor far forward (towards windshield). This position was approximately 45 degrees with respect to the line of the top of the windshield. I would imagine the dis-assembly is the opposite procedure.
Hopes this helps.
Best regards
Oct 28, 2010 | 2008 Honda Accord
Magellan 3200 when i plug it in it says connected to usb, i want the map
The power cord should have a round yellow plastic tip. It sounds like you're using a cord that has the mini-USB end and are plugging it in to the data transfer port.
Nov 08, 2009 | GPS
Drivers side visor broke is it fixable
there is an adhesive you can buy to stick it back onto the windshield. Autozone, pepboys, ect. have it.
May 31, 2009 | 1998 Chevrolet Malibu
I have lost the instructions for my Vodafone BT visor bluetooth
I have the instructions if you would like to give me your e-mail address i will send them to you
Apr 30, 2009 | Handspring Visor Prism Handheld
I need a user manual for thisSFK404 Bluetooth Visor Mount Handsfree Speaker but I cant seem to find one online so i could download it
didnt find any either too old but here is specs.
Model No: SFK404
Simply attach the Visor to the Sun Visor or any other suitable place, connect the Bluetooth hands free kit up with mobile and away you go.
Superb Quality simple Bluetooth Car Kit with Caller Id Display and Number Keypad for easier dialing.
Specifications
* Talking Time : 5 Hours * Standby Time : 150 Hours
* MIC : -47+/-1.5 * Power Consumption : Max 250mA
* Carrier Frequency : 2400MHz to 2483.5MHz * Transmission Power : Typ.1.0 dBm
* Operating Temperature : -20 ~ 70? * Storage Temperature : -40 ~ 85?
* Speaker : 8W, Max 1.5W * Digital Volume Control
* AC/DC Adaptor : 5.0V / 1A * Car Charger : Out : 5.0V/800mA
* Battery : 3.6V, 950mA Li-ion Rechargeable NK8200 series compatible
Main Functions
*Superior noise suppression *LCD Display - Caller ID/Calling time
*Excellent echo cancellation *Support Making/Ending a call
*Super full duplex *Support Voice Dialing, Number Dial
Compatibility : Compatible with all Bluetooth mobile phones
Profile : Supports for both Headset & Handsfree Profile
Bluetooth v1.1 compliant
CSR(BC02)
CDMA & GSM & TDMA
- Approvals : SIG, CE, FCC certified
FEATURES :
Last Number Called
Voice Dialing ( Providing the Phone Supports the feature.
Number Dialing
Speed Dialing
Selct wether to answer, Reject and End Calls
Volume Control
Power On and Power Off Feature to reserve battery power.
Rechargable Battery
Battery Power Status
Incoming Caller Alert ( Visor will Play a Meldoy and the Led Display will Flash Blue )
Connect to Pc for firmware upgrades ( Cable Supplied )
Bulit in Speaker
Built in Microphone
Bulit in 4Mb Memory
Noise Suppression
Echo Cancellation
Supports both Headset and Car Kit Profiles ( Phone Dependant )
Transferring Audio Feature ( Both from Headset and Handset )
Standby 150 Hours ( Uses a Nokia 8210 Battery so you can have a spare battery or simply purchase any nokia phone model in car charger to charge from your car. )
Talk Time 5 Hours
1 Year Warranty
Compatable with all Bluetooth Enabled Mobile Phones.
Handset supporting headset profile
Ericsson: R520m / R520m, T39 / T39m / T39mcc, T68m / T68mc
Sony Ericsson: P800, T68,
Motorola: A803, T280i, TimePort 260C V1.1
Philips: Fisio 825/826
Samsung: X7700
Sky: IM6200
Handset supporting handsfree profile
Motorola: V525, V600
Nokia: 6310 / 6310i, 8910 / 8910i, 3650, 6230, 6600, n-Gage
Sony Ericsson: T68i / T68ie, T610, T613, T630, Z600
Siemens: S55, S56, SX1
Panasonic: X70
Jan 22, 2009 | Cell Phones
Pama Sigma Sun Visor 2300 Bluetooth password/code
hi the factory password on the sigma pama is 1234 if you enter this on the phone once you find the sigma via bluetooth search it asks to enter the code to connect to the sigma most other devices ie bluetooth headset the code is 0000 hope this helps, regards smc
Dec 10, 2008 | Lands Phones
Rearview Mirror looseness
Note: You may want to remove the mirror from the windshield first to make the following steps easier. It's not necessary, but it's up to you. If so, pry off the plastic cover at the top of the mirror stalk, disconnect the power cord, and then pull the mirror downwards and parallel to the windshield to remove it.
Method 1: On the back side of the mirror below the ball joint, there is a small round cover. Insert a sharp blade tip at the top of the cover and carefully pry it out. Underneath is the tip of the tension screw. It has a slot in the end of it that can be tightened with a small flat-blade screwdriver. Carefully replace the cover, inserting the bottom tab first, then snap in the top. If the mirror is still not tight enough, go to Method 2.
Method 2: Carefully pry off the rim bezel of the mirror, starting in the middle of the seam on the bottom, working your way around the edge. The bezel will pop off when you get past one of the ends. I used a pair of heavy guitar picks to keep the latches from snapping back into place as I progressed. Once the bezel falls off, the mirror assembly will dangle from the power cord. The Phillips tension screw is in the center bottom of the case; tighten it to suit, and make certain that the four bracket mounting screws around it are all tight, too. Then place the mirror assembly back in place and snap the bezel back into place, starting at the top.
Sep 10, 2008 | Hyundai Motor 2003 XG350
GPS Logo
24 people viewed this question
Top Gold Lantern GPS Experts
Will Halftowaite
Are you a Gold Lantern GPS Expert? Answer questions, earn points and help others
