Question about RCA F20352SF TV
RCA Colortrax xs stereo tv Model FI9253BC No remote. Cable connection. How do I program this tv to show cable channels?
tvtek
  • 1284 Answers
SOURCE: Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Posted on Feb 23, 2007
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
bhur
  • 85 Answers
SOURCE: FPA LOCK ON MY RCA TV MODEL 27V513T
go to menu of your remote and unlock the fpa
Posted on Jun 11, 2008
mediarich
  • 188 Answers
SOURCE: not getting all cable channels?
Please post the model number of your TV. You have to get to the menu to reprogram the TV channels for cable vs on air. Sometimes pushing two buttons at the same time on the TV itself will get you into the menu mode. If you use Google and search for your modeel number and "manual" you might get some help there.
Posted on Nov 26, 2008
maatmartin7
  • 1216 Answers
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
Posted on Jun 26, 2009
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How do i connect my amp to my vizio tv there are right and left outputs on tv but only one input on back off amp
Typically you need an preamplifier between your tv and amplifier. you run one optical cable (or coax ) cable from you tv audio output to the preamplifier then you run audio rca cables from preamp outputs to amp inputs (2 for stereo 5 or 7 for surround). the preamp decodes audio and controls volume and surround modes.
If you have a cable box and need just simple setup for watching tv just run rca cables from your cable box audio outs to your amp inputs. you then program your cable remote control to control volume.
Oct 29, 2013 | B&K Reference 7250 5-Channel Amplifier
How to change the channels manually on a rca colortrax 2000 television
Set should have up down buttons---only a few models had all only on the remote and set has to have the channels programed into it for this to work.
Mar 16, 2012 | RCA Televison & Video
Was just given a 1995 RCA Remote Monitor XS Stereo Colortrak TV. Seems to work fine, but remote doesn't. Can change channels manually, but after about Channel 5, it skips most on the way up to 99. How...
Just about any One For All remote control will work with this unit and any other remote controlled devices you may have.
This sounds like when doing the channel scan the scan was interrupted and therefore went from the channels it had already found to the ones that were at the high end of the register. Also, when you are in the setting menu, you need to specify the input as either cable or antenna, preferably cable, which will also scan each channel from 2 through 125. Please let me know if there is more information you would like and I hope you have found this helpful.
Jul 01, 2011 | Televison & Video
I can not program the tv with the cable, which input goes with the cable channel. I have a 32 inch RCA with SRS . HELP
I do not see a question. "Which input goes with the cable channel?" Don't understand. Is there a cable box or SAT box connected to the TV? What kind of cable is running to the TV from the source? If you just have the coax cable going from the wall to the TV, then you need to auto format the channels. Select menu on the TV remote. Find Sources or Cable. Select "Cable" not "Air". Select Auto Format. May take several minutes. Input selector from TV remote should be "TV".
Jun 30, 2010 | RCA Televison & Video
How do I put the GE remote xs stereo monitor into input mode without the remote?
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
May 31, 2010 | GE Televison & Video
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
How do I install a channel to receive satellite programmes? My model is LE19R8
If you have a satellite and it is connected with coaxial cable put the set to channell 3 or 4. If the satellite is connected with RCA cableput the set on that source the cable are connected to. No need to program the set. Use the cable remote to change the channels just use the tv remote to turn the set on and off and for volume.
Aug 19, 2008 | Televison & Video
Televison & Video Logo
194 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
