Question about Refrigerators
Door ajar overnight. now will not cool.ihave unplugged and removed all contents ,used a hair dryer on the evaporeter coils and replugged
  • melfai Aug 20, 2010
    freezer door ajar overnight-slight airflow noted in freezer compartmentseems cool-cold but flow is inadequate
  • Refrigerators Master
  • 3,247 Answers
In such situations the compressor takes the beating. I am assuming it is still running but not able to turn the refrigerant around.
Have you touched the compressor to feel how hot it is?
You need an external fan to be targetted on the compressor. Not sure why you would aim the hair dryer at evaporator coils - I am assuming you were tyring to cool these and not heat up.
Unplug the fridge and leave for 30 minutes or so until the compressor feels cold enough to touch.
The other possibility is the freezer (I don't know model of your fridge) may have ice builtup and if it is auto defrost would have gone into defrost mode. Raise the freezer temperature setting to get the fridge out of defrost.
The worst case scenario is that the refrigerant is leaked and you may have to recharge the fridge assuming the compressor is still running.
Good Luck.
Posted on Aug 20, 2010
The freezer is frosty because the door wasn't closed properly . What is the correct way to defrost? Thank you
There are a couple of ways.
remove all the contents and switch the freezer off and leave the door open overnight with towels on the floor.
switch off and place a wide deep dish of boiling water in the freezer. close the door, replace water when it cools down. Defrost in a couple of hours.
switch off, use a hair drier.
Only use plastic scrapers to remove frost, never knives or metal objects which can puncture the element.
Sep 01, 2015 | Refrigerators
Old whirlpool upright freezer door got left slightly ajar. Light on inside. Rubber around door warm and won't seal.side of freezer warm. Stuff melting. What can I do?
Other than replacing the seal, you don't have many options. Theres two things you might want to try. First check the door alignment, make sure the gap is equal all around the door, Make sure a hinge hasn't moved. If it's just the seal being bent out of shape, you could try heating it with a hair dryer. Just run the dryer back and forth over the deformed area until the gasket/seal is soft, then close the door and hold it firmly in place while the seal cools. . . It may help. Good luck to you!
May 03, 2015 | Whirlpool Refrigerators
Model EP1chexbq00 no airflow on bottom: top freezer works but not bottom. Fan works.
Ok one of two problems. Either you have an ice block or you have a plugged drain. If you have a couple of dif choices. If you have a back up fridge than fill it with the contents of the broken one. Unplug leave doors slightly open for about 48hrs. Have towels for the water from the ice. Usually 2 or 3 bath towels. Plug back in and if the problem happens again within a week than your bi-metal ( defrest thermostat) is bad. To replace you have to remove the back panel in freezer and and on the condenser coils near top you will see a little round silver part.
Option 2- If no backup fridge or you have time. Have a hair dryer, 3 bath towels, a 1/4 inch nut driver (may be phillips) for screws. Unplug fridge and open freezer. Remove contents and place in ice chest with ice.remove screws from back wall pull panel forward. If you have an ice maker ther are two screws on the top where the ice fills at and one at the bottom. Also disconnect the quick connect for the ice maker. Remove back panel. You will see one of two things either all your coils are iced up (frost on all coils is normal) or two where it drains on silver plater has ice blocking drain hole. If ice is blocking drain remove and pour hot hot water down drain until it flows into drain pan in the back of fridge by compressor. If the coils are all iced up have towels ready. Start by putting a towel where it would normally drain where the towel is soaking up the water. Turn hair dryer on and melt ALL thee ice. some ice will be in the middle of coils and in back where you Cant see. Keep the hair dryer moving sitting in one place too long can damage wire and the walls of freezer. Melt all ice until no more water is falling from condenser coils. Than you will have to replace the bi metal. Put everything back in and plug in wait about 2 hrs before putting contents back in freezer. Just to let you know the the fridge will NOT cool down until freezer gets down to temp. Than the air will start cycling into fridge. If you have anymore question please feel free to comment me back for further assistance.
Jun 05, 2011 | Whirlpool Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
EXPRESS THAW LIGHT 3.0 STAYS ON AND COILS FREEZING UP
try unplugging unit overnight or unplug and use a hair dryer to defrost that coil, there are ducts near the coil that ice up as well so be sure and let them defrost fully
Oct 30, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Freezing coils
unplug unit overnight and let defrost,leave doors open , maybe assist with some warm air from a hair dryer
Oct 30, 2009 | Refrigerators
Have a frost free freezer kids left door ajar all
You should unplugged and let all the ice melt and help it with a hair dryer.
Oct 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer wont defrost and refrigerator is to hot
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Jul 20, 2009 | KitchenAid KSRG25FK Side by Side...
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
