Question about Logitech ClearChat Pro USB Headset
How do I get the Mute Light repaired - Logitech ClearChat Pro USB Headset
  • 864 Answers
To mute, press the mute button (the "logitech" logo). the mute light will flash when muted. Press the button again to unmute.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Posted on Aug 20, 2010
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Aug 20, 2010
    sorry i misread your problem i see you said how does to repair the mute light not how to get the unit to mute. To repair it your options are slim either you can open the unit up and solder in a new led light. Or you can pay a company to solder in a new led light for you. But that would probably cost as much or more then replacing the unit. I would just use the unit as is. As the mute light doesnt effect the overral function of the unit. Again sorry for misreading the problem
    Thanks and have a great day.
  • rra117 Aug 20, 2010
    Thanks
  • Nathan Ayers
    no problem if you found this helpful please feel free to rate the solution. if you need further assistance please let me know and i will be glad to assist you.
SOURCE:
Why does my Audiolab 8000s mute light stay on?
Your amp is probably in Protect Mode, meaning you have DC Offset( a damaged amplifier). That will have to be repaired, before you can switch the unit on. If you need more assistance, or would like to inquire about repairing it, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 30, 2014 | NAD C372 Amplifier
Power light comes on but individual mute and channel lights are not working . No sound outputting.
This is likely a power supply failure within the unit. Needs to go to a shop for repair.
Sep 20, 2011 | Samson S Phone 4 Channel Headphone...
Crate csx24 sound board- the mute lights will not light. Sound works but lights will not light.
USUALLY the Mute LED's for the switches ar operated by separate contacts on the mute switch an a resistor current limit for the LED. I could NOT find the schematic for this board, HOWEVER some Soundcraft brand mixers do NOT have illuminated Mute switches... Not sure about your particular unit.
Aug 04, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
I have an HP Pavilion dv7. Suddenly I have no volume. The mute light on the keyboard is orange and won't change to blue when I tap it. The mute volume icon at the bottom of the screen indicates that it...
Candy,
First thing is first, Thank You for visiting our site!
The problem you having is a HARDWARE issue with that push button interface in that HP.
what you can TRY
1. Take the batteries out of it
2. Unplug it totally from power
3. Pu the battery back in then power it on
4. Then push that button
If those steps do not work the laptop will need a new interface touch board. What is happening is its not recognizing your trying to turn the mute off.
The mute is off in the operating system DOES not construe for a fact that the issue is resolved if the button is still orange.
You will need a new touch board if the reset does not work.
You might want to contact support.hp.com to have them send out a tech or have it repaired by a authorized HP repair center in your area.
I hope you found this information Helpful!
Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Mar 22, 2011 | HP Pavilion dv9000z Notebook
How do i get mute off my phone
Well that would be hard to believe you can't get mute off since you have to personally initiate mute while during a call and the mute would be disable after you hang up. The mute button is located on the left side below the screen. Now here is what you might want to look at. Make sure TTY mode is off, this option would put your phone in permanent mute. Go to settings then to call settings, TTY mode should be off. If this still doesn't work and your phone displays "car kit" on the main screen then your phone is probably water damage or needs repair.
Jul 13, 2009 | LG VX8350 Cellular Phone
I have a J JVC RX-558V. The mute light is always on so it does not play sound. I can't find the key sequence on the front of the unit to disable Mute?
Apr 19, 2009 | JVC RX-558V
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
Akg sr 60
help me please akg sr60 , when torn on just mute
Dec 05, 2007 | Lands Phones
Logitech ClearChat Pro USB Headset Logo
542 people viewed this question
Top Logitech Radio Communications Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
