Question about Microsoft Windows XP Media Center Edition 2005 for PC
When I boot I get at times \system32\hal.dll. how can I cure this
  • 346 Answers
If the system tells you the the HAL.DLL file is corrupted or has been modified in any way, run a simple repair installed.
HAL stands for Hardware Abstract Layer. It's a blueprint of the hardware installed in your computer at the time Windows is installed. It was one of MS failed attempts at stopping people from ghosting their OS installations to other computers, but the fail part is that all you need to do is run repair install and it will create a new HAL.DLL file with a new image, negating the issue entirely.
Posted on Aug 20, 2010
My gateway lt 20 goes to a missing mess.about <windows root>\system32/hal.dll. immeditly on startup
If it cannot access any of the Advanced Boot Options, you may need to reinstall a fresh copy of the Operating System. However, try to run a hard drive diagnostic software to check if your hard drive has bad sectors.
For advanced troubleshooting on how to reinstall the file (system32/hal.dll) without doing a clean install, check the link below.
http://support.microsoft.com/kb/945380
Hope this helps.
Jun 09, 2011 | Computers & Internet
Notebook says that windows could not start because the following file is missing or corrupt &lt;windows root&gt;/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
On screen message telling me windows could not start because the following file is missing or corrupt- &lt;windows root&gt;\system32\hal.dll. Laptop does not start or boot properly
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors.
Hope that helps.
Feb 16, 2011 | ASUS Eee PC 701SD 8G Notebook
On start up <windows root>/system32\hal.dll.
Your Hall.dll is fine but you have to repair it.
ATTRIB C:\BOOT.INI -a -h -r -s
DEL C:\BOOT.INI
BOOTCFG /rebuild
FIXBOOT
Jan 17, 2011 | Acer Aspire One PC Notebook
Windows could not start because the following file is missing or corrupt: &lt;windows root&gt;\system32\hal.dll. How do i fix it?
hi, right you need to boot up using your windows disk, change the boot order so it picks your DVD drive first, now select repair once windows starts up.
Regards
GeWiz.
Please rate this if it helps.
Dec 18, 2010 | Acer Aspire 1640Z Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Motherboard 400M01 series - windowsroot\system32\hal.dll corrupted - don't know how to recover system from this error. It won't reboot - tried hotkey super recovery,etc. Nothing helps - my knowledge is...
Here's a very useful page which explains how to troubleshoot this error:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
Go through the list of suggested solutions. One of them should fix your problem with the corrupted hal.dll
Dec 03, 2009 | Foxconn Computers & Internet
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Cannot play old type of cd or dvd
HAL.DLL is Hardware Abstraction Layer. Dynamic Link Library. You will need to reinstall this file for the cd-rom to work properly. You can download the lastest version file from this web site: http://www.dll-files.com/dllindex/dll-les.shtml?hal
Jun 27, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
Microsoft Windows XP Media Center Edition 2005 for PC Logo
82 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
