Question about Acme 5001 Supreme Juicerator Juice Extractor
I need a shredder blade. Where can I get one?
    Champion:
  • 356 Answers
Call Waring at 1 800 492 7464.
Posted on Jan 30, 2011
I need to replace the shredder blade on my big boss juicer, where can i get a replacement?
Where can I find a replacement top lid for my Big Boss Juicer? I have been looking all over online but still have not had any luck. Thanks! -Danielle
Jan 26, 2012 | Juicers
My Omega 1000 is 10 yrs old, but I've only been using it regularly for 1 yr and 3 months. Putting a carrot through isn't stabilizing it anymore. It takes off when the screen is 1/2 full. But the weirdest...
Yes the blade is hitting it when the juicer vibrates
severely. I have an Acme, 21 years old, and found
very difficult to control vibration especially with a
new shredder blade. If you are handy this is what
to do. Order a new cover from omega, cover design
has changed so you will need the plunger also. This
may sound incorrect, but you will have to use a small
file to file down the cutting burrs on the blade a fraction
of an inch. Then with the juicer fully assembled, unlock
the set screw on the center of the bottom and turn it
clockwise until the chute contacts the blade then back
it off a half turn. Now the chute to blade gap is set
correctly. In filing down the burrs you make the blade
a little duller but you also narrow the gap and feed
the produce through more slowly and evenly. This
comes from 21 years of using this machine. With
a new blade I could not control the vibration no matter
how I fed the thing. If this sounds a bit too much get
rid of the Omega and try the pulp ejecting type. The
Miracle MJ1000 is a nice little juicer for about $130.
Jan 29, 2011 | Omega 1000 Juice Extractor
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
Excessive vibration and rattling when I have less than a cup of juice extracted.
I've had an Acme for 21 years and I don't care
what anyone tells you-they vibrate. After years
of trial and error I found mine vibrates less with
a worn blade that I sharpen with a drill. With
a new shredder blade you actually have to file
down the cutting burrs about one third and
adjust the blade to chute gap by unlocking
the adjusting screw on the center of the bottom,
turn it clockwise until blade contacts chute, and
back it off a half turn. Apparently with a slightly
duller blade, smaller gap, the produce goes through
more slowly and evenly. Also severe vibration will
cause the blade to jump up and chip the chute.
Dec 24, 2010 | Acme 5001 Supreme Juicerator Juice...
I haven't used my Acme Supreme Juicerator in years. How do you assemble the juicer? The flat blade sits on the aluminum filter? How does it attach to the motor? Am I missing a part
Juice bowl first, then the basket followed by the
shredder blade which is all held down by the
white clutch nut. If you're missing the nut ctc.
Waring at 1 800 492 7464 for a new one.
Nov 04, 2010 | Acme 5001 Supreme Juicerator Juice...
Who might sharpen the shredder blade???
This is a good one because a worn blade
actually causes less vibration. You can
sharpen the blade using a drill. Use a drill
bit about the same width as the cutting burrs
and drill into the face of each one ever so
slightly, almost perpendicularly. Assemble
the juicer and unlock the adjust screw on
the center of the bottom. Turn it clockwise
until the blade contacts the chute, then back
it off a half turn. Don't forget to tighten the
lock nut. I've been using the same blade
for years.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
SHREDDER BLADE, where can I find it for the ACME Juicerator model 6001?My email address is: peguero59@gmail.com
Contact waring directly or just google juicer parts. Believe Omega
juicers share same blade and it's cheaper. If your handy you can
sharpen you old blade by drilling, at an angle, into the face of each
burr on the blade. Use a 1/16 or 5/64 bit and do it ever so slightly.
Apr 23, 2010 | Acme 6001 Juice Extractor
Need parts
GOOGLE ACME JUICER PARTS. THE PARTS
YOU ARE LOOKING FOR ARE CALLED
SHREDDER BLADE AND CLUTCH NUT.
Feb 20, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
29 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
