Question about Microwave Ovens
The left front gas burner on my thermador rdf30 is not working. It has no gas flow. The ignitor works fine. The valve feels normal.
  • m4mj Aug 20, 2010
    How do I open the top to get to the solenoid?
  • m4mj Aug 22, 2010
    How do I open up the top of my range to check the solenoid?
  • 3,083 Answers
The valve might feel normal, but chances are that it's not working, and supplying gas to the burner. I would suspect that component above all else, and look into getting a replacement part. I'm not an appliance technician, per se, but it's either what's controlling the valve or the valve itself, unless, somehow, the line got clogged up. Here is a site that has diagrams of your oven, and might be of help to you:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=233307&diagram_id=194168#d194168 Here is a blog about a Thermador that had the same problem, and it turned out to be the valve: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/45460-thermador-range-grill-gas-valve-needed.html This blog is useful, since it explains how to check relavent components. Good luck, thanks for using FixYa, and hope this helps!
Posted on Aug 22, 2010
  • Microwave Ovens Master
  • 17,130 Answers
Remove the burner fron the top and use a good air jet to clean , use a good kerosene/diesel to clean the valve, the valve jets which can be definitely clogged. Since the gas is working on the other burners then it is for sure that the gas is blocked either in the valve secction, the jets, or the pipe is clogged.
Use a flexible wire bowden to clean , clean the jet and make sure the burner tops are fitting without a gap, if so use emery paper or file to clean rust or food dirt.
I am sure the burner will work after this service.
Helpful
Posted on Aug 21, 2010
    Genius:
  • 1,622 Answers
you can fixed this yourself,all you have to do is to follow the instructions below,
Check the solenoid valve for community, As the solenoid valves are a common point of failure, if that is okay check voltage, the valves use 110VDC to open , with only 60VDC change the simmer control, this comes in a kit with two potentiometer, this is located behind the sparks module under the top far right in the back.
With the parts mention replace all burner will work great.
Thanks for asking fixya a question....
Posted on Aug 20, 2010
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
The oven is gas - the top burners light, but the oven doesn't heat and appears to not be getting gas.
heatman101
Jun 25, 2011 | Microwave Ovens
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
When I turn it on, the heating element glows, but there doesn't seem to be any gas flowing through. I checked the valve, and it's open. Does this oven have a pilot light that needs to be lit?
The glow you see is actually the ignitor, it has taken the place of the out-dated pilot light. It is likely that your ignitor is partially burnt out and the safety valve is not opening. A good bake ignitor draws just over 3 amps and the safety valve will not open until it reads this 3 amp draw.
If the glow you see is a dull orange, it is likely that the ignitor is bad.
Apr 15, 2011 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
