Question about Onkyo Audio Players & Recorders
I have an onkyo R-805x that stopped working and makes a continuous clicking sound and no longer power up. Multiple people have posted this problem here but not info has been given. Is it the power supply or one of the boards?
Being a hospital electronics repairman (read I repair CT and MRI scanners), I recently had the pleasure of having our R-805x die on us with this exact same problem. I went through a lot of hoops to find the schematics on the system and what it came down to is the logic circuit on the main PC board, not the power board, has a logic control in there that is no longer able to determine the incoming voltage which prevents the system from locking in the relay on the power board. This is the reason for the clicking; the relay on the power module is energizing and de-energizing constantly.
I did not go any further than determining which board was causing the issue because ultimately it's going to cost about the same to repair (with shipping, headaches, man hours, etc) as a replacement system will be. I am currently researching replacment receivers for our MRI suite at this time.
Posted on Oct 06, 2010
Need e125a 125v fuse
http://www.intl.onkyo.com/downloads/manuals/pdf/r-805x_manual_e.pdf See page 4 of your manual at the provided link. This is the only mention of a fuse in the entire manual including plug specifications. 5amp.
Sep 15, 2015 | Onkyo For Parts R-805x Receiver
Paradigm pdr80 no sound
If it is a powered sub, the sub power supply may have failed. There might be an open fuse.
Dec 25, 2013 | Paradigm PDR 12 Speaker
Onkyo tx-nr509 no sound
check to make sure the speaker wire is not touching on the back of sterio or speakers. then shut off and turn back on. check the menu for speaker a and b and make sure it is turned on
Mar 13, 2013 | Onkyo TX-NR509
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
My older onkyo stereo system suddenly stopped producing sound.It turns on but usually when I press the power button it clicks once then about 5 seconds later another click puts power(and sound)to the...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 01, 2011 | Onkyo Audio Players & Recorders
Onkyo Rec(R-805X)does not work-constant clicking when plugged in
i have a similar problem, i plug it in and let it click to its hearts content, it will speed up to a very fast rate then slow down and eventually stop... then the unit will work fine for a couple of days but the clicking will return its not a permanent solution but it works
Dec 04, 2009 | Onkyo Audio Players & Recorders
ONKYO MC35TECH aka R-805X
Hi if you need a replacement plug for the system then you can buy them from any electrical store but if you want a transformer or anything product specific then you can contact Onkyo USA sevice centre on 201-785-2600.
Here is the Onkyo website where the number is from
. http://www.onkyousa.com/customer_support.cfm
Or for European service centres go here: http://www.eu.onkyo.com/indices/index_com_en_2008_5946251.html
Oct 29, 2008 | Onkyo MC35Tech CD Shelf System
TV Picture No Longer Comes On
Sounds like one or multiple Reservoir Capacitors in the Power Supply were starting to dry up. You also get problems like this from dry joints in the Power Supply. You need a technician to take a look for certain.
Jun 09, 2008 | Philips 27PT543S 27" TV
Power, but no sound coming from my speakers, checked fuses.
i have power but no sound it worked fine for a little while yesterday but it stopped whats wrong wit it
Mar 04, 2008 | Onkyo HT-SR700 System
966 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
