Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem with a Whirlpool Upright Freezer
We have a frost free freezer that's less than 2 years old. It recently has started collecting water in the very bottom of the inside of the freezer, which then freezes up underneath the bottom basket. I checked the drain pan underneath, and its dry as a bone. I am assuming that the drain line to the drain pan may be clogged, and not allowing the water to get to the pan. But I don't know how to find the drain line or how to clean it. Can you help?
  • 868 Answers
One way would be to unplug the freezer and allow all the ice to melt.It will open the path for draining.Then plug it back in making sure that there is know gaps on your door gasket that would allow warm air in which would make the same problem.
Posted on May 23, 2008
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
My frost free kenmore upright freezer collects frost around the top where the light is. I have checked the door seal and there seems to be no leakage. It is less than 2 years old
if frost free is collecting ice any where ther is a air leak . ck for poor seal.s seals sometime look good but not sealing . use a $10.00 bill a five won't work close the door on it in several places and ck the tennison . on tennison / bad seal /.. mm
Aug 11, 2010 | Refrigerators
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
Jun 16, 2010 | GE 203 cu. ft. General Electric Upright...
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Nov 04, 2009 | Amana 15.0 cu. ft. / 425 liter Upright...
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Freezer frosting up
I need more information. If this is a frost free freezer with an internal fan I need to know what the freezer temp is. If a manuel defrost it is supposed to frost up. You defrost it 2 - 3 times a year when the frost builds up over 3/4 inch. If it frosts up faster than this check to see if the door is sealing all the way around. There should be no gaps or cracks in the gasket.
Jul 10, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
