Question about Zephyr Typhoon AK2100 Kitchen Hood
How to locate the fuse for zeohyr 2100 hood. when i turn on the light a flash came and nothing is working. any suggestions? Thanks.
  • 22 Answers
See my post on the zephyr control board:
(control board is in the front of the hood behind the speed & light power buttons. etc )
Posted on Dec 20, 2014
  • 3 Answers
I have the same issue. I confirmed that there is power going to the unit.
Posted on Oct 02, 2010
When I'm driving my 2002 Ford Taurus will sometimes hesitate, the thief light on the dash will flash and if my cruise control is on it will go off; what is causing this problem?
Any body damage? Could it be that the hood latch or the theft switch is misadjusted, such that the normal vibrations of going down the road trick the theft system into thinking the hood is being opened?
Jan 07, 2015 | 2002 Ford Taurus
2006 Mitsubishi Outlander - cruise control, rear lights, phone charger stopped working
Check your Owner's manual for fuse location. You may a fuse panel under the hood as well as under the dash - driver's or pass. side.
GL,
Td
Oct 01, 2012 | Mitsubishi Outlander Cars & Trucks
Turn signal and hazard lights not working at all. Replaced Hazard fuse relay. All bulbs are ok as indicated when alarm activated with key fob. All flash as indication doors are locked but the turn signals...
Most likely the cause of your problem is a flasher module. Usually it is found in the fuse box under the dash. But it can be on the back of the turning signal switch. If you are unsure, contact the service department of your manufacturer and ask them the location of the module. They will know immediately.
Feb 05, 2011 | 2001 Volkswagen Beetle
I hear a clicking noise such as electrical points opening and closing in the area of the fuse box. As this happens the heater fan, headlights, inside panel lights, dashboard lights all flash. so it seems...
I believe you have a ground short in the main fuse wiring or at the main fuse location itself. Try locating it and as the suggested Tech from Firestone advised , replace the main fuse. frank
Dec 19, 2010 | 1994 Nissan Sentra 4-Door
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
No driving lights?
Hello there - I would suggest checking the fuse for your lights in the fuse box, and check under the hood for a fuse/relay box, and have the relay tested. If the fuses and relays are good, open the hood, and try to check the connection to the headlights and make sure they are securely connected. You also mentioned that when you push the headlights switch forward for brights, and turn on the night time head lights, and neither come on but the daytime lights do, makes me suspect the switch itself may be bad. I would first check the fuses and relays if any. Second, I would replace the bulbs (if replacable). Other than that, my last guess would be an electrical problem in the wiring somewhere. I hope this information helps you fix your lights. Thank you for your time and consideration in my suggestions/answers.
Apr 01, 2009 | 1996 Mazda 626
98 gmc truck
replace the relay for the headlights located in the same fuse box under the hood.
Robert
Please take a moment to rate this solution.
thanks
Feb 01, 2009 | 1998 GMC Sierra
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr Typhoon AK2100 Kitchen Hood Logo
942 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
