Question about Roper REX4634KQ Electric Dryer
NO HEAT DRYER RAN OVERNIGHT WITH OUT TURNING OFF CLOTHES WERE STILLL DAMP ONLY COOL AIR. DRYER IS ONLY TWO YEARS OLD
  • 66 Answers
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
Posted on May 03, 2008
Dryer not drying
Not a major appliance expert--but if the situation is as described with hot air out vent but not in the drum where the clothing is it seems to me you have a blockage between the drum and lint filter to where it reaches the vent tube---they do make long flexible brushes for this-----a suggestion: if you have a compressor try forcing air down from the lint filter with the vent tube removed to see if the blockage is there and will clear or not.
A blockage can be a fire hazard so if you do not find it have a tech out.
Dec 04, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
Whirlpool Duet Electric Dryer
make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Feb 17, 2009 | Whirlpool GEW9250 Electric Dryer
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Roper REX4634KQ Electric Dryer Logo
113 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
