Question about Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP
Amana Free O Frost 25 ft side by side with ice maker inside the freezer. Stopped making ice cubes this week. The unit is 22 years old. The rubber tube leading to the ice cube tray seemed like ti was frozen with water inside, so no more can enter the system. Any suggestions for figuring this out would be greatly appreciated.
Illeagle
  • 525 Answers
SOURCE: Snow or frost in the
Based on the information you provided you will have 2 scenarios here:
1. If frost is building up on packages or around the front then look for an air intrusion, i.e. something blocking the correct door closure (either door). Bottom basket not pushed in all the way, etc.
2. If frost is on the rear panel where the fan is located, then you would have a failure in the defrost system. Now, either you will find that #1 is the problem, which, at this point, that is what I believe, because of your food status, or you have been super observant and have caught a potential food loss issue in its early stage. Once a failure in the defrost system occurs, it will normally take 1-2 weeks before the unit can no longer absorb heat out of the box, due to excessive frost build up, and the unit will start warming up. Below is a link to a parts breakdown and diagnostics help if you determine that you have a defrost system failure.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 19, 2008
mastatech
  • 478 Answers
SOURCE: water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Posted on Mar 12, 2009
lojacksdad
  • 121 Answers
SOURCE: bottom freezer, ice cubes melting and refreezing.
defrost timer saying off to long
Posted on Apr 17, 2009
aasc
  • 1606 Answers
SOURCE: Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Posted on Aug 12, 2009
  • 78 Answers
SOURCE: Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Posted on Aug 28, 2009
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
The ice maker stopped working .There is water in the plastic tube in the back of the refridgerator but it only gets to about 3/4 of the way up the tube. The water dispencer stopped working years ago but...
Pour about 1/2 cup of water into ic emaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the ice maker . Also make sure the fridge coils are clean and free of dust , lint , pet hair , etc..
VE6GAR 73 88 99...thumbs up..
Aug 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water does not reach ice tray, ice maker appears to be cycling
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE MAKER STOPPED MAKING ICE
the water line can freezer .. there is a water line heater kit...check the black rubber inlet it may have ice in it...let me know if it helps
Aug 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
302 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
