Question about Kitchen Ranges
Rayburn Nouvelle two knob oil control valve - cannot get replacement. Low flow rate to cooker burner - after 20 years I understand a waxy deposit may for on the oil regulator/needle valve. can I dissamle to clean of drain and put in sovent? Regards Richard
4 Suggested Answers
  • 149 Answers
SOURCE: rayburn nouvelle smoke exhaust from boiler burner
normaly this little seal and washer is enough to keep the smoke in
you must have a unclear flueway. i would remove and clean the baffles in the top of the boiler burner first that make sure i have an updraught in the main flue pipe then try again
Posted on Mar 20, 2010
  • 149 Answers
SOURCE: rayburn cookers
http://www.rayburn-web.co.uk/DirectoryList.asp?SD=Rayburn obsolete cookers/Rayburn Royal MF/
paste all that to go to the rayburn manuals download site i have seen this manual and it shows what you need
Posted on Mar 23, 2010
  • 149 Answers
SOURCE: High running costs for gas fired Rayburn central heating
these are now a redundant range parts are no longer available and a good thing too as they cost the earth to run. gas ones cost more to run than oil. try "top of the range ltd" for a solution
Rayburn troubleshooting
www.rayburn-web.co.uk/raytech/default.htm
Aug 26, 2014 | Heating & Cooling
The heater is only kicking on low as the wate demand goes up the temperature of the water drops because the heater is not kicking up like it used to. The heater is a little over a year old.
See image larger
-Tankless water heaters are susceptible to lime build-up if not de-limed each year.
-Hard water will clog pressure-sensor and cause failure within 2 years if filter and softener are not working.
-Water flow and water pressure sensors inside tankless are succeptible to hard water deposits.
-Low water pressure from clogged pipes to municipal water problems to water well pressure valve can affect tankless burner
-Low-flow shower heads may not engage burner.
-With tankless-gas water heaters, sensors inside combustion area detect when incoming air flow is not adequate ... inspect inflow
-Your manual probably has a troubleshoot section.
-The manufacturer will refer you to installer.
-If you self-installed unit, that will void warranty to my understanding.
-There are water heater forums 1 2 3 4
-There are plumbers who will each have a different opinion
-There are Fixya experts who get paid to tell you the above.
-And there are local plumbers who are authorized dealers of the brand of tankless who get paid to fix them
Oct 07, 2010 | Rheem Tankless Hot Water Heater...
Strong smell of burning oil from chimney of rayburn
the replacement burners seems to not to be set up right. the chap should have had a analiser to make sure the settings are right.you need to call in a pro with the right kit and someone who knows how to use it. your cooker can kill when running like this do not use it
Feb 26, 2010 | Kitchen Ranges
Rayburn nouvelle smoke exhaust from boiler burner front pipe joint-copper small od. metal washer and rope seal!
Feb 07, 2010 | Kitchen Ranges
Rayburn 480 ag, pilot goes out
rayburn nouvelle thermocouple keeps burning out any suggestions
Dec 25, 2009 | Kitchen Ranges
Dec 20, 2009 | Kitchen Ranges
Could you tell me if an oil fired rayburn will run ok on red diesel, I live in spain and kerosene is not available. thanks peter williams
if it is wick burner it will not work. if it is a single pj a gas oil burner can be fitted that will work. if a twin pj then it will work if you turn up the fuel pressure to 12 bar
Nov 29, 2009 | Kitchen Ranges
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Low and Slow heating to temperature on grill
Here are some tips:
Check: The excess flow safety device, which is part of the barbeque to cylinder connection, may have activated.
Fix: To reset the excess flow safety device turn all burners control knobs and the cylinder valve OFF. Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. Turn cylinder valve on slowly. Then use your like you normally do.
Now the line is purged.
Fireplace-Girl
Apr 29, 2008 | Weber Genesis Silver C Grill
Kitchen Ranges Logo
227 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
