Question about Casio Parts Cash Register PC Desktop
Casio ce-3700 how do I clear error code E04 please?
    President:
  • 1,257 Answers
E-04 Key in mode switch was turned before completing last opereration. Turning key to X then pressing subtotal usually fixes problem.
For more innformation use link below
http://www.olskey.com/support.html
http://www.olskey.com/casioshooting.html
Was this solution helpful? Show your Appreciation by rating it:
Thanks
Dilip Bagdi
Technical Associate
Posted on May 03, 2008
  • Deeps . May 03, 2008
    E04 is "Mode switch position changed before finalization", the manual suggests "return mode switch to original position and finalize operation"
    But - if you don't know what was being done at the time that the error was caused I don't know how to fix it??
    I've spent ages going through the various key positions pressing combinations of button #37 & sub-total but none of them have made any difference...
    Thanks
    Dilip Bagdi
    Technical Associate
    Genius:
  • 3,422 Answers
These are the two methods you can try to fix your problem:
Error E04: means that a clerk switch was done
if you try the second solution this should reset the erc to a default programm...11501 depending on the ECR's IPL installed.
First method:
Make sure that you keep the journal key down when switching your key from off to pgm and wait couple of seconds before releasing it.
A display with all zero confirms the operation, then enter
11501(I am not sure,will check),depress Sub-total wait for
a tone or a receipt.
if tone : looking for ecr network designation depress Sub-total and should see that It has become an independent ECR.
IF Receipt: everything is fine.
If you have clerk push button depress #1 (default Clerk key)
Go to REG position and try a default Dept and Tender should have been loaded.
Second method:
put the key in off position
press the journal feed
while pressing the journal feed, turns the key in to the program position
releas the journal feed key (the display shows a lot of zero's)
press 11501 and press subtotal.
when there's a receipt print turns the key back into the reg position.
the ecr should now work, with a default program.
Goodluck,
Please don' forget to rate the solution
    President:
  • 2,712 Answers
Hello magrat,
error E004 means : Initialization or unit lock clear operation in progress
Well, the solution according to Casio, is to let the operation complete. So just wait a while and hopefully all should be OK.
Should that not work, you can contact Casio Live Support at +1 800-638-9228 at the following times:
9:00am to 8:00pm
Monday - Friday
9:00am to 5:00pm
Saturday/Sunday
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If your issue is not resolved, please do not assign
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved (remember that at times a bit of
    to and fro dialogue may be necessary to resolve an issue).
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated.
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    IrishDruid
  • Casio Master
  • 19,396 Answers
Try first disconnecting from power for ten minutes, if it does not work you need a fabric reset
  • Ginko
    Ginko May 03, 2008
    check also whether there is any paper jam with the printer.
The lcd display an error code ....E04-01...and i need to get into service mode to clear the message..thanks help please
Did you make a repair or replace the fuser and need to reset the code?; Because if you didn't fix the problem, you'll still get the same low fuser temperature error code.
Press <function>, <original size (ledger)>, <3>
to enter service mode, go to F9-05-04 (RAM Initialize, fuser reset, power off/on)
If the E4-01 error code returns you have a defective thermistor/thermostat.
Nov 22, 2013 | Panasonic WORKiO DP-C262 Printer
E04-10 error code
Good morning, people. I would like to know how to eliminate the E04-10 error in the panasonic DP 8016 p. Could someone help me please
Sep 26, 2013 | Panasonic DP-8020 DP-8016P Toner Black...
Panasonic 3510 E04-02 error code Can you tell me how to correct this please? Thanks
You most likely have a blown thermal fuse or thermostat in the fuser assy. After replacement, you have to enter diagnostics and perform an lbpr fuser reset. That's in F9-6
Jun 15, 2010 | Panasonic Workio DP-3520 Copier
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Panasonic FP-D355 Error Code E04-01
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Jan 16, 2008 | Panasonic Workio DP-3530 Copier
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Casio Parts Cash Register PC Desktop Logo
680 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
