Question about Whirlpool LSR7333 Top Load Washer
The control panel is not working the water keeps filling up
    Champion:
  • 245 Answers
This is called your water fill diaphram. Or your water level select. Replace it and you have fixed the problem. You might want to check the hose for holes or to see if the hose popped off the switch. The same thing happened to my cousin. Good luck!
Posted on Aug 20, 2010
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
Washer won't stop filling
Does the water stop filling if machine is unplugged? If yes, bad water valve inside washer.
If water stops when unplugged, may be a faulty pressure switch or airdome hose came loose from switch - located in control panel - water level switch.
If water keeps filling and never overflows onto floor - likely that water is siphoning out drain hose. Raise drain hose higher or allow an air break at the drain hose exit.
Jan 21, 2011 | KitchenAid KAWS750L Top Load Washer
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
Washer won't fill up
if there is no water on the ground or over spilling then pause the machine and lift the drain hose up until you here the water stop coming out of the hose.
keep the hose up to the top of the rear control panel and restart the machine it should fill up and go in the wash cycle
May 28, 2010 | Estate TAWS850PQ
The washer keeps on filling up until is begins leaking, it will not shut off when it has reached the load level by itself
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Jan 08, 2010 | Washing Machines
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
WATER WON'T SHUT OFF WHEN FILLING
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Sep 30, 2009 | Maytag PAV2300 Top Load Washer
Water keeps filling and doesnt go to next cycle
Sep 03, 2009 | Washing Machines
AWO3561 washing machine- FH keeps showing on the machine, we have changed pipes and filters but still the machine does not work. water fills machine but water continues draining through the outlet as it is...
Please refer to your owners manual in the installation section. The drain pipe probably needs to be as high as the height of the control panel. or 36 inches.
If the drain hose is lower you have a siphon problem, the machine fills and the drain is lower the water just runs to drain.
If this is not the problem you may have a control problem and the control is running the pump.
Ask if you have more questions.
T
Jul 07, 2008 | Whirlpool Washing Machines
Whirlpool LSR7333 Top Load Washer Logo
18 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
