Question about AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner
Need to find blower motor for mastercool swamp cooler mod. # mmb12b
  • 107 Answers
Easiest way would be to take the motor to a local Electric Motor repair or replacement shop. All mediaum to large cities have them...
Posted on Aug 21, 2010
  • Brian Kirk
    Brian Kirk Sep 06, 2010
    Typically what does motor repair cost?
  • Patrick Worley
    Patrick Worley Sep 07, 2010
    for this small of motor they would get you a replacement.. Probably under $100.00
Swamp coolers
Does it come back on automatically and how long does it take?
May 16, 2014 | Mastercool 67680 Evaporative Cooler Air...
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
My Mastercool Trio System has experience a failure od the compressor fan. ACExperts, the installer and only dealer in El Paso has gone out business.
is this not a Evaporative cooler if so there is no compressor the only two motors one for the Fan and a Sump pump. and most you spend 200 for fan motor. this is swamp cooler!
Jul 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Remove the front and rear panels off of a MasterCool P12
Lift yhe panel and pull out at bottom. The ones that come out usually have hand slots
Jun 09, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Mar 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner Logo
254 people viewed this question
Top AdobeAir Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
