Question about HP w1907 LCD Monitor
How do i get OSD Lockout to stop poping up on the screen?
    Problem Solver:
  • 9 Answers
My HP w2408 monitor. I just fixed this issue about 5 mins ago after getting tierd of whacking the buttons with anything handy. There are 2 slots on the underside of the monitor, in between the black frame and silver outer frame. Stick a flat screw driver and use a motion as if to literally pull the black frame away from the monitor. Use caution and dont stick the screw driver too far in. You will hear it pop. Do the same to the other side. There are multiple tabs arond the frame including one in the bottom center. Keep pulling on the free ends of the frame till all the tabs come off. Now you will see the buttom assembly, disconnect the small white connector from the montior. If you dont care for the buttons, which if you have a w2408 or any such model you will never use (auto detects input and auto adjusts) then just pop the frame back on. If you want to go further remove the 2 screws on the button assembly pull down on the silver frame to remove the button assembly. I did not go further then this but i read somewhere that if you wash the assembly in some liquid it will work again. I am guessing some good acohol from walgreens will do. For me I am just glad the message when away.
Keep fixing and keep sharing! Corporations that sell to the masses will show respect only when the masses unite.
Posted on Aug 21, 2010
  • chchristy Aug 25, 2010
    Great advice! However, when I disconnected either the small white or small black connector the power button didn't work. So I undid the 2 screws on the button assembly, removed the board, and broke off the metal grounding for the "Menu" button since that was the one that was stuck. The groundings are square metal with a black circle (that the plastic external button compresses). Success!
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
Osd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
Osd lockout
osd is ON SCREEN DISPLAY.
Jun 10, 2009 | HP w1907 LCD Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
HP pavilion vf15 monitor (OSD lockout)
this could be a bad button connection or the osd IC chip is failing for some reason that would need to be tested to determine why.
so if you can take it apart then clean the button and the plastic of dirt , and check the contact button to see if it looks faulty or check it to see if it is making contact all the time
if those are not the problem then it is the IC chip and will need testing to find the culprit
electech
Nov 22, 2008 | Computers & Internet
HP w1907 LCD Monitor Logo
214 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
