Question about Cameras
Olympus stylus 300/400, does not switch on when front cover is moved over, can be switched on to veiw only with button on back
  • John Mucci Mar 22, 2009
    My Stylus 300 had the annoying problem of once it was open and all the settings ready to go, the slightest touch to the door closed it down. But now when I slide the door across nothing happens -- and I can't even see the photos by hitting Quick View in the back; I rrecharged the battery and even changed the battery and nothing seems to work.
You may be sliding it to fast.
Posted on Jun 21, 2008
How to reset sz-15?
With digital cameras there are no things like reset buttons or procedures. Just switching off and on, or removing the battery and reinserting it, will restart the camera like a cold boot from a computer.
When you touched the lens barrel, while it was moving, and the camera acts strange. Switch it of, remove the battery and the memory card. then reinsert them and switch on.
May 01, 2014 | Olympus STYLUS SZ-15 Silver Digital Camera...
Please help my Olympus Stylus Tough 6020 seems to be stuck in playback mode. I can review the photos no problem but when I press the button to change the mode to take aphoto the screen reverts back to...
Unfortunatly the Olympus 6020 does not hav a dedicated hardreset switch, nor a key sequence to initiate reset. So if you cant get into the camera menu, and reset the camera from there. Or if that does not work. The camera has to be serviced by proffesionals.
Mar 08, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
Flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 30, 2009 | Olympus Stylus 410 / ? 410 Digital Camera
I have an olympus Stylus 800 and the flash stop to work. The camera only works withou flash. What you recommend me. Thank you.
If there is a red squiggly flashing icon on the screen this is actually a repair issue with the camera. The flash charging indicator switch needs to be replaced as it seems to have malfunctioned. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $133 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 04, 2009 | Olympus Stylus 800 / ? 800 Digital Camera
Check card cover- Card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $100.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 26, 2009 | Olympus Stylus Verve / ?-mini Digital...
Olympus Stylus 600/Digital 600 6.0 megapixel
Hi
This camera can be very picky when it comes to the front lens cover... It's not a simple mechanism and has many small parts and gears involved. If the lens cover is dislodged it won't work smoothly, and if the case is dented it will not be able to move properly and this can cause lens problems.
If the lens was out when the camera was dropped, then it's possible the lens was damaged and not the lens cover. Sometimes you can tear down the lens, clean it and rebuild it and it will work smoothly again, sometimes this doesn't work and the lens needs to be replaced.
If you're comfortable opening the camera, first check out the lens with the front body section removed so nothing is blocking the lens cover. Does it work properly now? If not, then expect lens damage to be the issue.
We are an AFFORDABLE digital camera repair shop... if we can assist you with parts or do the repair please let us know. (google: darntoothysam)
Hopefully this is of some help. Even if you don't use our services please feel free to let me know if you need more assistance.
Good luck from Darntoothysam com
Thomas
Oct 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Casio Pocket Viewer PV-S400Plus not working
When batteries are to be replace you must move the switch on the back cover to "replace batteries". After you replace the batteries, you must move the switch back to "normal operation". The unit will then want you to touch the dots in the cross hairs and then ask you to adjust contrast. Try replacing the batteries again with a fresh pair. If this does not work, open the cover with the switch in the "replace batteries" position and use your stylus to press the "P" button underneath the battery cover and try again. If this fails, try resetting the unit.
Jul 25, 2007 | Casio Pocket Viewer PV-S400 Plus Handheld
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
May 07, 2006 | Olympus Stylus Verve / ?-mini Digital...
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
