Question about Jl Audio 12W7 Car Subwoofer
I have installed a 12" w7 and jl 1000/1 v2 amp. I was useing the bass knob untill i found out on the jl website that its not needed for this set up. I was haveing problems blowing 80 amp fuses so i went to a 100 amp fuse. The same thing happened. went to a 150 amp fuse now the sub just quit working. the fuse isnt blown and the amp is on. what do i do next? just check the input sensitivity is all i can thank of. do you have any suggestions.. thanks
  • 58 Answers
It is NEVER a good idea to increase the values of fuses . Chances are you have internally damaged your amp. The next time you are faced with this problem you need to find out why your amp is blowing fuses and not keep changing the value of the fuse.
Posted on Aug 20, 2010
I have 2 jl audio 13w7 and 2 mono 1000/1 amps one for each woffer, one of the woffers blow. this set up is in a ported box. I was just driving to work bumping it like around 25 and the speaker startd to...
check your bass leval on your amp and make sure it is the same leval as your other amp. Also you w7 can be repaired they just change the coil. cheeper than buying a new one.
Sep 05, 2009 | Jl Audio 13W7 Car Subwoofer
JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Trouble with jl amp
well start with. turn your hi pass completely off. Turn your bass boost completely off. Turn your input gain copletely down. and turn your cd player to about 3/4 of what you listen to it at. Then turn your input up until it starts to sound a little dirty(distortion) then turn it down a notch. set it at a 80 herz filter so it allows nothing over 80 herz to come through. I just installed one of these jl amps a week ago. 1400.1 and it made two kicker cvt's sound amazing just have to set it just exactly like i told you. it will hit tight as hell and loud and it will hit all frequencies way better.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Amp assistence
The jl100/1v2 puts out the same amount of power between 1.5 - 4 ohm loads so you dont have to really set up anything to match your sub- wire the coils in parrallel and plug it in- set infrasonic(subsonic) filter at 15 hz(lowest) set crossover piont at close to 80 hz set gain about half-or if you kow the voltage from your source unit match the source voltage to the amps input voltage setting-it should pound like a champ with no problems
May 20, 2009 | Jl Audio 1000/1 Car Audio Amplifier
My amp cuts off when i turn it up
do you have the amp knobs cranked?? gain and freq
May 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000\1 v2 and 13 w7
it depends on how you wired your 13 w7 did you wire the dual voice coils up or down?? the w7 comes with a book and it has the 1000/1 settings you need and then there is a guide that comes with your 1000/1 v2 and on page 14 it tells you how to set the gain accordingly to your ohm load for perfect sounds with little to no gain overlap (you can set the gain louder if you don't want maximum sq and are not worried about clipping cause a 1000/1 shouldn't blow a 13 w7 from overpowering only from clipping (and since the w7 are practically bullet proof clipping takes a long time)
Nov 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
Jl Audio 12W7 Car Subwoofer Logo
152 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
