Question about Sport & Outdoor - Others
I have a ZHNG TBX150-B, 2009, Motor Scooter from Boreem Motor Sports. I am having trouble starting. I filled the gas tank but the gas gauge shows empty. It starts only for a few seconds and then quits.Is there a fuse or in line filter that may be the problem?
  • 2,926 Answers
Pull the spark plug and inspect it for fouling. it may be fouled down inside preventing good spark. You can also replace it if you have not done so in awhile. Let me know.
Posted on Aug 20, 2010
My 2010 Mazda 3 is showing full tank of gas when it's actually almost empty therefore it will not accept more gas.
If you cannot fill the tank because of an erroneous reading then it is time to replace the gas gauge sending unit responsible for the anomaly. Hope fully you can do it from the trunk - otherwise you will have to drop the gas tank to gain access.
Jul 31, 2016 | 2010 Mazda MAZDA3
Boreem gas scooter tankman needs flywheel housing ...basically one whole side of motor cause this cover same piece in which one of motor mounts ***** is...asking proper way to search this part
Boreem Tankman Scooter Parts - Boreem Parts - All ...
www.monsterscooterparts.com/trsc/rec-brands/boreem/boreemtankman
  1. Cached
Items 1 - 16 of 16 - 12 Volt 1.0 Amp (1000 mA) 3-Prong QL-080414-B1201500H Battery Charger. ... 8mm 05T Chain 20 Tooth Drive Sprocket for 49cc & 52cc Gas Scooter Engines. ... Select your model below to view all known compatible parts including tires, tubes, pull starts, wheel assemblies, and much more!
Neoscooters: Boreem Scooter Parts, Boreem Gas Scooter ...
www.neoscooters.com > ... > Boreem Scooter Parts
  1. Cached
  2. Similar
Boreem parts and acccessories for Boreem Gas scooters. Chargers ... Boreem Ironman XR Scooter Parts. Boreem ... Boreem Tankman Scooter Parts. Boreem ...
Boreem Pocket Bike Parts Parts - Tankman Parts - Scooter ...
www.scooterpartssale.com/index.php?main_page=index_bike...id...
  1. Cached
  2. Similar
Products 1 - 28 of 208 - Parts catalog - Carry with chinese made Boreem Pocket Bike Parts Tankman Parts.
Mar 26, 2016 | Miscellaneous
NEED WIRING DIAGRAM/OWNERS MANUAL FOR BOREEM TANKMAN 49CC SCOOTER
Hi, Chip sorry you can't find the first and best tool you ever bought for your BMW despair not for a mere $10 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.christmashow.com/boreem-electric-scooter-wiring-diagram-owners-manual.pdf
Wiring diagram for boreem tankman 49cc scooter Mobility Scooters
Dec 28, 2015 | Motorcycles
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
Dash gas gauge stops showing proper gas level once it hits half a tank. Then gauge will fluctuate between empty (light will come on), full and anywhere in between but seems fine from full tank to half
If the trouble with the gauge started after you worked on it then you likely damaged or created a restriction to the movement of the sending unit. You will have to remove the tank and double-check your work.
Mar 01, 2013 | 2000 Buick LeSabre
I have a xingyue xy260t-4 with 2000 miles on it. I am having a couple problems. The first is the fuel gauge reads empty most of the time. Sometimes it will go to half. Any idea what might be wrong? Next is...
My scooter dose the same with the gas gauge it seem to be the reading gauge in the tank if you fill it up and ride it for about 40 miles you will see the gauge go up to full as the gas starts to go down.
Jul 17, 2011 | 2011 Xingyue Xy260T4
Gas gauge shows empty after filling gas tank. Eventually the gas gauge will register the proper level.
The gauge circuit is shunted on most cars, this is wierd, but needed to stabilize the readings... Your description sounds like normal function. Drivers would complain if the qauge were to be instant, going around corners, starting, stopping, all move fuel, and the gauge would indicate this, cauing driver alarm...Been this way for ever, although yours sounds like it is on the far side of the scale...if it reads correctly after a while, you could replace everything and you would have the same performance.
Sep 05, 2009 | 2005 Buick Terraza
Boreem Jia Scotter - Model ID and manual?
how do i change the battery on my boreem jia series electric scooter
Aug 23, 2009 | Cycling
Sport & Outdoor - Others Logo
79 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
