Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirpool model ed5vhgxmq10 icemaker not working, no water getting to ice tray,put water dispenser solenoid on ice valve and water would go to tray when water dispenser pushed,cannot swap wires from one to the other because connectors are different size, ice side solenoid reads about 235 ohms, water dispenser solenoid reads about 300 ohms, water solenoid clicks when water dispenser pushed, cannot get sound from ice solenoid, is ice solenoid controlled by another switch or motor?
watugot
  • 290 Answers
SOURCE: amana scd25tw
It sounds like you have covered all the primary troubleshooting checks. There is only one thing I can think of at this point.
Check the voltage coming to the water valve during the icemaker cycle. The power to the valve is decreased by the resistence of the icemaker heater from 120 volts down to about 108 volts. It is not uncommon to have a valve that will open when you put 120 volts to it, as you do when you switch solenoids, but not open at the decreased voltage when it goes through the icemaker circuit.
If you are getting voltage to the valve when it cycles, and you know for sure the water line to the icemaker is clear, then you will need to replace the valve.
Post back and let me know what you find.
Posted on Nov 11, 2007
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
SOURCE: Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Posted on Jan 08, 2009
SOURCE: Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Posted on Feb 05, 2009
whytfang
  • 170 Answers
SOURCE: No Ice & no chilled water from frig.
First off does this model have a water filter if so...and if it is old and or full of filtered material the water will not dispense anywhere.
Ok...the way to test for power is obviously with meter you can easily check the solenoid leading to the inside of the frig by exposing where the connectors attach to the solenoid...but do not remove them completely you should have a continual 110/120 v supply...someone at the front of the unit can depress the dispenser and you will hear the solenoid activate...if it does not...the same should apply for the ice maker solenoid...unless it is activated by the timer (electrically) and not mechanically (which it usually is) if you are getting voltage to both of these....and you have voltage to the primary solenoid...(which you may not) if you do not have a filter...and both of the other valves stopped working at the same time..(which would be rare). Then there may be an electrical problem in general. Also you can check to see if the firdge is cold enough to make ice by manually filling the Ice maker with water...it should freeze in under 4 hours and dump the ice also...if it does...them it lies in an electrical problem in general or electrical problem to the primary solenoid. Also do you have hard water....as it may be posible for calcium deposits to accumulate at the valve inlets...and often there are tiny screens in place here also. Check for water continuity at the valves if possible.
I hope this helps....good luck and get back to me and we can go from what you find out.....please rate me.... the Fang
Posted on Mar 27, 2009
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
My ice dispenser quit working
There are multiple components that can cause this.
Open the door and put your finger in the ice tray. Is there any ice or water in it.
If so then the problem is likely the ice maker.
If not then the water supply is either stopped up or the water valve solenoid is broke.
If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
Thanks for using FixYa, Good Luck.
Mar 03, 2011 | GE Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
Fridgedair R134a ice maker water wont fill. Solenoids & valves are good & water supply lines good. Im works fine. So, where does the signal to the IM solenoid & valve originate from. I already...
Your icemaker send the voltage to the water valve as it cycles through its ice drop. Pull your icemaker out, and test the wiring it was plugged into for continuity to the water valve, usually you will only have one colored wire that has continuity. Your white wire is usually your nuetral and as long as both wires are ok, then replace your icemaker or your icemaker module if it has one. You have a very good parts house on Oahu called Reliable Parts, Take your icemaker in if you live on Oahu, or call them with your parts number if you are on the Big Island. I worked on Oahu for 15 years. Good Luck Appliance Specialists
Dec 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
NOT GETTING ICE NO WATER IN ICEMAKER TRAYS
if it is dispensing water but not making ice and there is water in the well your 2 way water inlet valve needs to be replaced,it is located on the back bottom of the frig.,turn the water off remove the valve and go to your local applince parts store,they run about $20,let me know how you make out,thanks-mike
Apr 12, 2009 | Refrigerators
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
Just had this issue - after checking all line connections, I pulled the ice maker feed water line from the back of the unit and found the tube was blocked with ice. Melted the ice with some hot water, and all is good once more. I would check for this before getting into the solinoid.
Aug 27, 2008 | Refrigerators
No water to the ice maker. No voltage to the inlet solenoid
icemakers work on a timed cycle and a timed fill. pressing the reset switch i would say solved your problem. I would switch the valves back to the way they were. The valve for the ice is smaller then the door water because the icemaker takes a small amount of water to fill. Good luck
Jul 21, 2007 | LG LRSC26910 Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
240 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
