I have a hotpoint aquarius WMA50 washing machine tht is making a dreadful noise when it spins although is still effciently removing water. What do you think the problem is and how easy would it be to fix?
    Problem Solver:
  • 12 Answers
Bearins not a easy job if you need parts for any machine try sales@gwhitedist.co.uk
Posted on May 04, 2008
Where is the water filter kept on the hotpoint aquarius wma50
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum, filter is located inside the hose.
Sep 19, 2010 | Hotpoint WMA50 Front Load Washer
Drum has stopped moving
Hello, these is usually the drive belt,the drive belt is the easiest parts to replace.
Thanks
Jun 10, 2010 | Hotpoint WMM39 Front Load Washer
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi, i have a hotpoint aquarius 6kg wma50, my
Have you checked for blockage in the pump. Or the have been some problems with a ball that sits in the hose between pump and the drum. This can block the water. Check this berfore purchase new pump.
Jul 26, 2009 | Washing Machines
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Hotpoint WMA50 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
