Lcd tv screen has gone dark there is a faint picture and sound tryed to use brightness but made no difference
  • jandculver Jan 18, 2009
    picture has all 3 colors but went dark and no controls will help.
    President:
  • 2,712 Answers
1. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
2. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
Dynex dx-l321-10a no video
No video or no brightness? If no brightness on a LCD get the room very very dark and with a flashlight on the screen look to see if a faint (very faint) image of the picture can be seen or not.
Dec 17, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
Olevia 265TFHD 65
FIGURING OUT YOUR PROBLEM IS ONE THING, BUT FINDING THE PARTS WILL BE THE BIGGEST CHALLENGE. I HAVE A OLEVIA 255TFHD AND IM CATCHING HELL FINDING PARTS. SYNTAX BRILLANT, THE COMPANY THAT MADE OUR SETS HAS GONE OUT OF BUSINESS. PARTS ARE SCARCE
May 11, 2012 | Olevia 237T 37 in. LCD TV
Hi the tv started to go dark then it would be ok then dark and the same when dvds played do get sound now black screen nothing at all
Hmm
Looks like the back light or the driver circuit has failed.
If you shine a bright torch at the screen can you see a very faint image ?
If so then its the back light has gone.
If you cant see anything its the screen driver.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Grundig GU19WDT 19 in. LCD TV
I have no picture on my 15" LCD Insignia TV. My
You may have a burnt out blacklight... You can fix it easy by having the tv on while it’s a bright picture than quickly unplugging it... or it would be best to get a new TV.
Oct 27, 2017 | Insignia 15 in. Flat Panel LCD HDTV
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
LCD TV has sound but no picture.
Shine a small bright light at the screen when on and see if you can see a faint picture in the dark screen. If you can then your backlighting is not functioning due to ccfl (inverter), power supply, or back light lamps.
Mar 27, 2009 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Why has the picture on my tv gone too dark to
have sound but picture is too dark to watch on tv
Mar 21, 2009 | Televison & Video
Televison & Video Logo
280 people viewed this question
Top Televison & Video Experts
Electro Med Services...
