Question about EliteGroup P4M800-M7 Motherboard
RAM P4M800-M7 problem
First thank you for your help
the problem is that the P4M800-M7 don't accept any RAM (memory ddr1)
except the first one installed one year ago which is a ram DDR 1 (333) if i change another with the same specification it doesn't work
and with this ram (the first) only dod is operating (via floopy) if i begin to install windows (millenium or XP)
it is blocked just in the beginig of installation
best regards
this is my email z_touf@yahoo.fr
  • 34 Answers
Try to clean the ram slot then try again . Also read the motherboard manual if it supports your new ram or not .
Please rate me .
Posted on May 06, 2008
ECS MOTHERBOARD NO BOOTING UP
They must have correct ram installed.
Hard to believe all 10 are faulty.....sounds like a ram fault.
Could also be wrong / faulty CPU
Apr 12, 2010 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Replacing memory on the P4M800-M7 A motherboard
No. Just make sure that you two RAM modules have the same specifications (speed, clock).
If you don't know about that, then simply insert both RAM modules and start your computer. If Windows loads, then right click on MyComputer and go to properties. If it shows 1.5GB then you are OK.
If the computer fails to start or you hear multiple beeps it means that they are incompatible.
Replace the 512 module and insert the new one and try again.
Always remember to turn off the power and unplug the cable from the power supply before replacing RAM modules.
Jan 28, 2010 | Biostar P4M800 Pro-M7 Socket 775 mATX MB...
Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
The motherboard supports 2GB maximum memory. 1x1GB in each slot.
Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
Please remember to remove the power cord before installing the new ram.
Regards.
Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
Hi..i have a P4m800-M7 rev 3.1 motherboard which recently had only 1 512MB DDR 400mhz RAM.. itried to install an additional 256MB DDR 400mzh ram but the system recognizes only the 512MB RAM. I've tried...
Check that your memory is supported, according to Biostar documentation for your motherboard:
Single Channel Mode DDR2 Memory
Registered DIMM and ECC DIMM is not supported
Re-check the memory module's specifications.
Nov 03, 2009 | EliteGroup P4M800-M7 Motherboard
Elite group P4M800-M7 Can i use 2GB 667 / 800 ddr2????
I have p4m800-m7 also and i cant seem to get both sticks to work.....I still have only 1 gig with both sticks i have 2 DDR-2 1Gig sticks PC2-5300 533 mhz
Mar 12, 2009 | EliteGroup P4M800-M7 Motherboard
RAM DDR2 PC 1300
DDR 2 will _not_ work the way it's supposed to in a DDR slot, if at all. If you want to see what memory your computer can use, go to crucial.com or similar website for a free scan of your computer. From the spec. sheet it looks like your machine takes a maximum of 2 sticks of 1 gig each (for a total of 2 gigs) DDR SDRAM, either 333 or 400MHz of memory
Feb 07, 2009 | EliteGroup P4M800-M7 Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Is P4M800-M7 mobo can support the pc333 sdram memory? Thank you.
Yes, according to the specs that I read the P4M800-M7 (socket 775?) is designed to support pc333.
Only one time I had a problem with an ECS motherboard, I had the correct memory, but the board had a different voltage requirement. Did not cause any issues, other than it didn't work. I don't think that this would be a problem for you though.
Oct 14, 2008 | EliteGroup P4M800-M7 Motherboard
Computer freezes during game
first of all you should know that even though pentium 4 isn't that old there are still some problems, for example the d processor uses sd-ram or ddr1 ram which are much slower that ddr2 and ddr3 "ddr1 isn't that slow" but if u're using SD-ram then u might wanna upgrade your rams a bit.
Dec 23, 2007 | Biostar P4M800-M7A Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
131 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
