Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Compressor runs great but pops off at 125 then bleeds down to 80 then tries to restart.i have changed high presure pop off.
  • 3 Answers
It souds like a sticky "non return valve". See the fix below.
The non return valve is the chrome part with a hex cap adjacent to the upper tank. Remove the cap and make sure the piston moves freely. Slight resistance is ok, but if it sticks your compressor willl continually blow off air.
The check valve or "non return valve", as listed in the Hitachi parts manual is definitely the culprit here, but there is an alternative solution to replacing the entire valve that was actually suggested to me by a Hitachi Tech when I stopped by my local service center to pick up a new non return valve. Obviously, the rubber piston swells and sticks to the point that the spring under the piston can't over come the friction. I removed the piston and carefully reduced its diameter, by hand, with varying grades of wet or dry paper and it now operates perfectly. If one is uncomfortable with such a repair, at least keep it in mind for a quick jobsite fix. I have now been running my repaired compressor for several months without issue.
Posted on Aug 23, 2010
  • mwsn Sep 29, 2010
    Could have saved some money if I read this fix first. Thanks
September 3, 2010 reply: Your sandpaper solution worked perfectly. Thanks.
Posted on Sep 02, 2010
  • rick15 Sep 28, 2010
    This fixes the problem of blowing off or dumping air. It also solves the problem of the motor not starting or laboring. If this valve is working correctly, then the motor does not have to start against the high pressure in the tank.
    Thank you for the fix. It worked perfectly.
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I bought it new about 2 yrs ago? What needs to be done with this problem? I noticed on this...
Hello;
150 is your cutout pressure. It's the factory setting and is not a problem. But, It appears you have a pop off (safety) that is set for 125 psi, So, If you want 150 psi, the pop off needs to be adjusted. If you want 125 the the cut out switch needs the adjusting. The setting. More than likely the 125 psi pop off valve is correct and the switch needs to be adjusted down below the pop off pressure. To sdjust the switch, remove the cover of the box the cord comes out of.Adjust using the screw(s). There should be one for cut in and another for cutout pressuressures. The cut in pressure should be 90 psi and the cutout should be at 125 psi.If the pop off valve blows off at 125, It needs either replace or adjusting. It's best to replace it.since the spring inside has lost tension. You will be constantly adjusting it otherwise. Good Luck -Ned_ Take caution not to get your tool or fingers into the electrical in the switch box.
Apr 15, 2011 | Dewalt & 2HP Hand Carry Heavy Duty...
My stanley compressor will not shut off untill the safety pop off valve activates
The pressure cut off setting is too high. Locate your operation manual and adjust the pressure to the manufactures specs. Normal shut off pressure is @ 125 psi.
Feb 15, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
My ec 12 compressor will run and shut off around 125 psi and then it bleeds off untill it turns on around 80 psi Ive replace the pressure switch and its still doing this Why?
Jun 25, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Compressor shutting down
FC IS FREON CHARGE, WHAT YOU ARE GETTING IS A HIGH PRESURE CUT OFF  FAILURE. THE LABEL PRESURE IS TEST PRESURE. THE RUN PRESURE ON LOW SIDE IN AC MODE IS ABOUT 65 AT 75 T0 80 DEGREES INSIDE AND ABOUT 200-300 HIGH SIDE AT 75 -85 OUTSIDE TEMP. IN HEAT THE LARGE COPPER LINE BECOMES HIGH SIDE HOT WHEN YOU FEEL IT. IF YOUR FREON IS LOW WILL WILL ALSO GET SHUTDOWN. YOU WILL NEED SET OF FREON GAGES AND CONTACT ME BACK
Apr 23, 2010 | Heating & Cooling
I have an IR Air Compressor #SS3 E. It want stop running/building up pressure. I am sure its the pressure relief valve, but there are 2. One at the presure regulator and the other at the pump and motor.How...
if it is lifting both valves I would say that the pressure switch (regulator as you call it) is defective, if you try to shut it off using the manual switch and it keeps running, I would say that the switch is welded shut. if it does not shut off by 125 psi then it is faulty. The pressure switch is what controls the motor in response to pressure in the tank.
Jan 31, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Saylor-beall air compressor D-B-200-HA builds up to about 120 psi and shuts down but it bleeds down to 80 psi and restarts do I need a new pressure switch or can it be adjusted? it has adjusting screw on...
I am almost sure what you have is only a single pump and should only rut out 125 psi tops. you should not exceed this with a pump of that type. If it is a 2 stage pump (one large and one small cylinder) they can commonly go to 175 psi. But as always check to see what the maximum pressure your tank was certified and do not ever exceed it.
Dec 08, 2009 | Air Tools & Compressors
Pop off valve on return line leaking compressor keeps running turn compressor off stops leaking whats up?
Once the pop off valve reaches its opening point, it will stay open as long as the pressure is above that point. When you shut the compressor off, the pressure leaks down until the pop off valve closes. Sounds like the pressure regulator is set a little too high. If you can turn the regulator switch down, it should fix it.
Cabinetman54
Nov 18, 2009 | Air Tools & Compressors
Constant popping
THE POPPING SOUND IS PROBABLY COMING FROM A PRESSURE RELEIF VALVE ON THE HEAD OR INNERCOOLER. THIS TYPICALLY MEANS THE VALVES IN THE HEAD ARE BAD AND RARELY THIS VALVE IS BAD. DO NOT PLUG THIS PORT. YOU CAN TRY CHANGING THIS SAFETY VALVE-PAY ATTENTION TO THE PSI RATING ON THE SIDE. SINCE ITS A DAYTON IT CAME FROM GRAINGER AND YOU CAN GET PARTS FROM GRAINGERS 1-800 PARTS SERVICE. TRY TO FIND A 5 DIGIT PART # SOMEWHERE LIKE 5Y670, ETC. YOU CAN PROBABLY GET A VALVE REPAIR KIT OR THE ENTIRE VALVE PLATES. PAY ATTENTION WHEN DISASSEMBLING AND MARK DIRECTION OF PARTS. HOPE THIS HELPS, JODY
Apr 22, 2009 | Air Tools & Compressors
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
646 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
