Question about Garden
The weedeater FX-265 starts, runs with the throttle held in place, then idles down after you let go of the throttle for about 7-9 seconds then stops. Why does it not stay running?
  • 718 Answers
You need to rebuild carb. Go to smalleng.com they have great rebuild videos.
Posted on Aug 21, 2010
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
2013 Honda Activa will not idle when warm
Hi, P and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jun 28, 2014 | Honda Activa Motorcycles
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Trying to start weedeater. Starts but wont continue running. we just replaced the fuelines need to know how far down the blue line should be in the tank.the olds ones were dry rotted so we re not sure if...
There should have been a fuel filter attached to the fuel line. So when installing quite tricky, put line in tank, place filter on end of line while in the tank, let filter lay flat on bottom of the tank.
In those carbaretors there are gaskets and a diaphram. After awile they ware out and the diaphram which is rubber gets hard, so it will no longer pump fuel. You can buy everything for the cab in a kit. I hope this helps you.
Jul 14, 2011 | Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Fuel/accelerator problems. dies when accelating or at idle. runs when accelerator held in one position for a short while.
CHECK THE IDLE SPEED SENSOR, UNPLUG IT AND SEE IF THE VEHICLE REVS UP A BIT. IF IT DOES, THEN REPLACE IT. ALSO CHECK THE FUEL PUMP RELAY IN THE FUSEBOX. HOPE THIS HELPS. .LET ME KNOW. GOOD LUCK
May 03, 2009 | 2000 Daewoo Lanos
Idle runs too high when I come to a stop, for about 5 seconds.
The throttle body may need to be cleaned. Take off the induction hose to the throttle and open the plate. Make sure the vehicle is not running. With the throttle plate wide open, soak a cloth rag with carb and choke cleaner and work the rag around the inside of the body especially where the plate's closed position is. remove the rag and spray a small amount of carb cleaner down the throat of the throttle body. replace hose and run vehicle at 1500 rpm's for a few seconds. This should fix the idle. It should be idling at about 800 rpms.
Apr 24, 2009 | 1999 Saturn SL
96' Intrepid with Eratic RPM
Sensor could be broken or wiring.
Nov 03, 2008 | 1999 Dodge Intrepid
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
