Question about Vacuums
Where can I find an owners manual fo a Hoover "NanoLite" Power Brush Vacuum Cleaner Model # U2440-900?
reddevil6
  • 1673 Answers
SOURCE: Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Posted on Mar 18, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
Posted on May 15, 2008
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
CorvetteKing
  • 108 Answers
SOURCE: On my Hoover Savvy U8174-900 on carpet setting,
Hoover savvys have two very common problems that cause this. The first and most obvious is the belt that you checked already. Many times the belt is tight but those particular belts have teeth and should you lose any teeth on the brushroller OR the belt it can cause this.
The other problem this is a symptom of is a bad switch in the handle. It sounds odd but the switch assy in these machines controls 2 motors, one that causes vacuum another that causes the belt to turn! Often time that switch assembly is bad and the smaller motor that drives the belt does not run when the handle is in a certain position. This causes your brush to stop but since the louder bigger vaccum motor is still operating you never hear the small one quit. I would run this again and listen for a difference in sound. In this case you will buy a replacement circut board that is installed in the handle (i usually replace the entire handle assy, the small extra cost is worth the dependability as nobody can seem to determine for sure what makes them go bad)
You can get the parts from any hoover service center, use their dealer locator to find the nearest one. Be sure to take the old parts in and compare when buying new, hoover makes running changes to their product so 2 machines with the same model number can be different.
Aside from a stray bad or pinched wire you're more than surely dealing with one of those two items. I'd focus on the first paragraph as that is by far most common and least expensive.
Best of Luck!!
Posted on Jun 09, 2009
  • 294 Answers
SOURCE: Where can I find a user manual for a Hoover Steam
The manual can be downloaded at Hoover.com for your exact model
Posted on Oct 11, 2009
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
How do I replace the smaller belt that attaches to the brush
Hello! Follow the steps below to replace the v-belt on your Hoover.
1. Slide flat belt off large pulley.
2. To remove v-belt, slide back of belt over pulley. Then firmly pull on belt and snap it off. Discard used belt.
3. To install new belt (with lettering on outside of belt) slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will pop into place.
4. Insert brush-roll through belt and position belt in groove on brush-roll.
I have also included a link you may visit to view the owner's manual and these instructions.
http://hoover.com/file/509/
Jun 30, 2014 | Hoover U6476-910 WindTunnel Upright Vacuum...
Hoover deep cleaner brush won't work
If the vacuum cleaner comes on but the brush will not spin, try replacing the belt and clean each end of the brush from lint , string, carpet materials.
Oct 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
I have a hoover spinscrub carpet cleaner model F7221-900 I need to download a user manual for.But hoover website tells me they can,t find this model number. I have checked # several times and it is...
I just needed to clean the brushes I finally just found the clips on each side of the brush roller and pressed in towards center and was able to pull brushes out.
Mar 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Possible broken belt..brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=748077
Possible broken belt. Brush doesn't turn
Posted by Helene on Jul 06, 2008
Possible broken belt. Brush doesn't turn on Sanyo Revo SC TA3000 vacuum. Cannot find manual.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Sanyo factory phone # and or your local vacuum cleaner dealer for the belts. But the owner’s manual you would have to contact the Sanyo factory @ the phone number provided below. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://us.sanyo.com/appliances/vacuum_cleaners/
Customer Service – Go to the Contact Us page and fill out the email request
The Service Center Cust Serv Line 1-800-421-5013
Monday thru Friday 7:30 AM to 5:00 PM (PST)
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
