Question about LG Heating & Cooling
I have a 10000 btu model# lg1000er. the radiator unit on behind the dust screen keeps freezing if i put it on low temperture
  • 148 Answers
SOURCE: coils and raidiator freeze up in minutes
chances are you may need a bit of freon might have small leak on the flares
Posted on May 15, 2009
MsMithra
  • 79 Answers
SOURCE: just bought a kenmore 10000 btu window a/c unit - need to install
You CAN put it on the 3rd floor as long as you make sure it's completely secure. One thing I do recommend is building (or buying) a window unit shelf that sits outside the window and the air conditioner sits on it for extra support. The shelf is secured by the window frame.
There are many "how-to" guides to building a window unit shelf all over the internet.
I hope this helps.
Posted on Aug 17, 2009
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Posted on Aug 18, 2009
  • 674 Answers
SOURCE: We have a 10000 btu frigidaire window unit and it
Part of the function of an air conditioner is to dehumidify the air in the room being cooled. The water dripping out the back is the water being removed from the air in your house.
Posted on Jun 20, 2010
  • 230 Answers
SOURCE: Where does the water drain
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Posted on Jul 02, 2011
My gree mini split 2400 heat pump air conditioner does not turn off at the set temperture when cooling
I am not sure about your specific model. However most A/C units I have worked with have a fan switch. The switch allows you to choose to have the fan on all the time or only when the unit is cooling. Some of these switches are behind the front panel, behind the panel or out in the open it should be close to the other controls. Hope this was helpful.
May 24, 2014 | Gree 24,000 BTU 18 Seer Ductless Mini...
Freezing up inside my a/c unit
Often that is a sign it is low on refrigerant. It can also be due to low air flow due to either a dirty filter or dirt obstructing the fins (coils) behind the filter.
Jul 23, 2012 | Haier 5,000-BTU Mechanical Window Air...
Danby DAC10011E 10000 BTU window air conditioner not draining water? does it have some sort of self evaporating technology? I can hear water inside when I turn it on and/or off, but none draining out the...
Hello, some window units do not use a drain tube instead they use the condenser fan blade to scoop the condensate from the bottum of the base pan and splash the condenser coil to keep the condenser cool and also evaporate the condensate. Most of the time you can hear a "swishing sound"
Jun 18, 2012 | Danby Dac10011e 10000 Btu Window Air...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
Where can I buy this model???
THis one is an 8000 btu unit the one in the link is a 10000 btu unit which will do a better job. http://www.a14electronics.com/product-p/FRRZQ10C10.htm
May 02, 2011 | Friedrich ZStar ZQ08A10A Air Conditioner
Not pulling down to temperture
The most common problem is low refrigerant (freon). If you don't have gauges to check the pressure of your refrigerant, do this: the compressor has one small line running to the coils on the top of the freezer. That small line should be hot enough to burn your finger if you touch it when the compressor is running. Also the big copper tube running into the compressor should be cold to the touch, almost freezing. If not you are probably low on refrigerant. Without gauges and the ability to buy freon, you will need to hire a refrigeration repair service to find the leak in your system, repair it and then gas it up. But there are a couple of other things to check first. Near the compressor is a radiator like set of coils in front of a fan. If the compressor is running that fan should be running too. if not, the unit won't cool. Also the radiator coils may be covered with dust or grease. You must have a good flow of air through these coils to dissapate the heat put out by the compressor.If it is stopped up, brush the dust from the front of the coils. Look inside the freezer as well and make sure the inside coils are not frozen over. Is so unplug the unit and let the frost melt off. If that is happening you may need a new timer on your drfrost system.
Oct 08, 2010 | Traulsen 69.1 cu. ft. / 1957 liter...
Charlie
Aug 18, 2009 | Maytag Electronic Portable Air Conditioner...
Just bought a kenmore 10000 btu window a/c unit - need to install
I hope this helps.
Aug 17, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Why does my a/c unit keep freezeing up?
Dirty filter,dirty evap coil or low on refrigerant. Rus. The first you can handle the last call a service tech
Jun 14, 2009 | Haier HSU09XCA 9000 BTU 10 SEER Rating...
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
