As the wiring on aftermarket signals is not standardized, you will need to determine which wires are ground, running, and turn respectively. If you can disassemble the signal, the ground will be connected to the outside of the socket, and the other two will be running and turn. If you cannot disassemble the signal, or have access to a multimeter, you can determine which wire is ground by checking continuity between the outer socket and wires. Your stock green wire is the ground, and the orange/white is running light. If when you hook the wires up, your running light is brighter than the turn signal, switch the leads.
Hope this helps.
