Question about Nokia 6100
Hello, I have a nokia 6100 and when I try to turn it on, all it shows is a blue screen. I went to the beach with it and when I arrived home it was like this. You think that has anything to do with it? And what can I do to fix it?
  • 600 Answers
Well, possibly yes if the phone went into the water, or spilled water on it.
If you are saying that it is now blue screen, check first if it still emit sound, try pressing buttons and hear out sound coming from it(keypad tones etc), or try calling or texting the phone, if the phone rings or can be contacted or recieves messages, or you can even call using it, the damaged part is the LCD, have it replaced.
If the results are the other way around, possible that it may need re-programming or aso possible is a hardware fault, again have it checked by a technician.
Dont try to push the LCD in an attempt to fix it, it may cause more damaged than anything good, the LCD might crack, or even worse puncture or tamper the connection points of the LCD to the board, might get it grounded of some sort.
The best solution is have it checked by a technician. Dont try to open the phone by your self, because, again, the LCD connector of that particular phone is just a snap on with a thin connector board, wrong procedure in taking the lcd out could cause the connection on the board to go with the lcd connector, rendering it somewhat useless phone, because it is quite difficult to reattach the connector to a tampered board. hello, I have a nokia 6100 and when I try to turn - 6dc0010.jpg
this is what will happen if you remove the lcd wrong
note the two pieces on top of the lcd, those are the connector of the lCD, and the connector that is connected to the board, it is now tampered.
Posted on Aug 20, 2010
SOURCE:
My nokia 6100 have no network signal searching manual mode shows "no network found"
I had a cell phone that did this, after it got wet. It went through the wash... I had to get another phone.
Jun 28, 2010 | Nokia 6100
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Nokia 6100 keystrokes to copy numbers from phone to SIM
use pc suit and copy the contacts to pc...
Aug 11, 2009 | Nokia 6100
Nokia 6100
maybe there is a virus on your phone,you better try to format it and if the problem still come again,try send it to phone shop and ask them to fix it for you...gud luck..:,)
Jun 27, 2008 | Nokia 6100
Mitsubishi 60603
try switching your pip to the main screen and see if the pip shows blue while the main screen works.
May 29, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Nokia
hi..hello...how r u??
Dec 26, 2007 | Nokia 5300 Grey Cellular Phone
Nokia 6126
Try taking the battery out and refitting it, that might do the trick.
Dec 05, 2007 | Nokia 6100
Nokia 6100 Logo
136 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
