Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
My unit will not start. Even if I put gas on the plug to prime the unit . Any help
  • 718 Answers
Check for spark then get back to us..
Posted on Aug 21, 2010
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the brass bolt (main jet) that holds the carburetor bowl on (don't lose the external washer with it) and clean it extremely well. Use no metal objects on this part. It has very small holes in the bottom and sides. Clean until nice and shiny and reinstall.
Toro 6.5hp recycler won't start, it's guaranteed to start! How's that?
When did you last have it serviced? What engine is fitted to your machine? Dies it have a munual choke, primer or auto choke? Any of these can go wrong if not regularly serviced
Aug 26, 2014 | Garden
It won't start.
Prime away... on a chainsaw it does NOT squirt fuel into carb. It draws fuel from tank, through carb, and returns it to tank.
Using the choke however will flood it in a second once it has fired. with a good fuel supply, 99.5 % of chainsaw won't start problems are flooded. Lou
Nov 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
Nov 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
HB-180 Leaf blower won't start
if its flooded then it surly wont fire,not a 2-stroke. are you over priming or is there a malfunction. remove plug,put plug not a tester in the end of lead,ground, and pull. spark should be purple and consistent. if red/yellow/intermitent. change he plug. if the engine is only flodding on its own then the needle and seat could be stuck open in the carb, gas tank vent in fuel cap plugged and building tank pressure, or fuel mixed too rich. let me know what you find
Sep 02, 2009 | Homelite Consumer Products MightyLite...
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
2004 nissan titan...ran out of gas
Good chance that even on 4 gallons it may not start I would try for more, prime the fuel pump several times by turning the key on and leaving it on for around 5 seconds then shutting it off and repeating, obviously not trying to start. I've had cases where even small FWD cars won't start even on 4 gallons on a 12 gallon tank. The newer fuel pumps are a closed system that only allow a small portion of fuel into the pump housing to keep contamination down. Let me know if after adding a few more gallons it won't start we will trouble shoot from there. Thank you for using fixya.com
Jul 02, 2008 | 2004 Nissan Titan
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
143 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
