Question about Miele Novotronic Premier 500 Front Load Washer
W1930 I put in a normal load and water starts to fill, but soon cuts off. Too soon! Then the machine seems to go thru its normal cycle, including spin.  At the end, there is usually very wet clothes in the washer, as if they did not spin dry but as if there was still water in there. The front of the washer is not glass, so I can't see  whats going on. From other articles it seems like its the pressure vessel clogged or something like that. If it is could you step me throught he process of cleaning that out. I am not very mechanical so more detail would be better. I can get a friend to help me and I'd like to try to do it. Sound familiar? Thankis Tamara
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (4 to 6 inches maximum) Of course you can direct the hose into sink, fine. Snaking out your standpipe would be good too.
Also open up behind, you will see a thin tube coming from the control area to the water exit area, near pump below. Disconnect this tube carefully from the top and blow into it. It should be free, or you will have bad water levels in machine; the tube should not be torn or kinked; refit carefully. Good luck Tamara
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your problem will be back for someone else to solve.
Posted on May 31, 2008
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Fisher Paykel will not drain
I had the same problem. After cut the power off for at least 60 seconds and then back on, as the manual suggests, the problem remained. Therefore I started putting the clothes out and bailing the water out. Once the water was down about half way the pump started working. I suspect the sensor was "stuck". I cycled the washer without clothes and it worked fine. Still working after several loads of laundry. The water level sensor will probably need replacing sometime soon.
Dec 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing machine broke
I have the same machine and had the same problem. It turned out that the outflow trap which contains a plastic ball had filled up with junk out of pockets etc and also with strands of fabric from cloth nappies. If you remove the drain hose assembly(unplug the machine first!!) by unscrewing the jubilee clips on the hoses(this is inside the rear panel of the machine at the bottom) you can rmaove the outfloe trap take the ball out and empty out all the junk. Check that the hoses are clear as well and then check no junk remains where the part attaches to the bottom of the drum.
Put everything back together and run the machine for a full cycle with no clothes in it this should remove any left over bits of junk.
I have had to do this four or five times in the two years I have had this machine but it runs fine and washes perfectly until too much jnunk is in the trap, then it has the same symptoms you describe, wont finish the cycle, wont spin. On one occasion it poured water out of the powder tray, again same problem!!
If the machine has stopped full of water you will have to abort the programme unplug the machine, plug it back in then open the door catching the water in a large container then follow the procedure above. Water will drain from the hoses when you take them off have some towels handy!! Good Luck, Al from Manchester
Jan 07, 2008 | Hotpoint First Edition WMA22 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
81 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
