Question about Euro-Pro Toaster Ovens
Model TO140L It does not heat. The timer still works and lights up, but no heating function works.
  • 11,800 Answers
This happens because the coils inside aren't powered. You will need to open the oven and test the continuity of the coils with an ohmmeter. If they are ok then the relay powering them is fried and must be replaced.
Posted on Aug 20, 2010
How can I troubleshoot my kitchenAid toaster oven? The timer works but the light will not go on, and it will not heat up on any setting.
The heating element went bad. The manufacturer makes it impossible to open the unit and doesn't sell parts - the lawyers told them it is too risky to let consumers repair toaster ovens.
Sorry.
Feb 25, 2015 | KitchenAid KCO222OB Countertop Oven
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
Toastmaster Toaster Oven 357 is not heating when door is closed?
Mine just broke too - it won't heat - everything else works - lights, timer ect. but no heat can't cook
without it - love my oven - any solutions ( I guess it's the heating element ) Hope I can get a new one.
Aug 29, 2009 | Toastmaster 357S Cool Wall 1400 Watts...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Timer switch on Dualit 89100 1500 Watts Toaster Oven does not work so oven cannot be used. Any advice?If you turn timer all the way to 120 minutes and hold it the light in the oven will go on but no heat.
The timer switch is likely bad. Small convection ovens are notorious for this problem and switches may be difficult to find. Try smallapplianceparts.com or search "small appliance parts" for a few places that sell parts. You will need the make and model # of your oven.
Feb 22, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
172 people viewed this question
Top Euro-Pro Toaster Ovens Experts
eyecam
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Euro-Pro Toaster Oven Expert? Answer questions, earn points and help others
