Question about Brother MFC-7220 All-In-One Laser Printer
BROTHER MFC-7220 When I print paper comes out with black line on right hand side of the paper. Its like somebody took a black marker and ruler and made a straight line from top to bottom.
    Novelist:
  • 175 Answers
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
Posted on Mar 02, 2011
I have to print out a paper right away, could you help me?
If it still prints ignore it.
if you rather call the vendor. Ifyou're under warranty. They may replace or repair it.
Apr 18, 2015 | Brother MFC-7220 All-In-One Laser Printer
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
My brother mfc-7220 printer show"toner
You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
Sep 21, 2011 | Brother MFC-7220 All-In-One Laser Printer
How can I print a history report on my Brother MFC-7220 Plain Paper Laser Fax?
The report you want is called "Fax Journal, and it's number is 4.
Press "Reports" button (in the upper-right corner of the panel), then either go down (using up/down arrow keys) to "Fax Journal", or press number 4 directly, then confirm with "Menu/Set" key.
By the way, click here to download a PDF manual for your unit.
Good luck, and please leave testimonial if helped :)
Jul 06, 2010 | Brother MFC-7220 Plain Paper Laser Fax
We have brother MFC-7220 All-In-One Laser Printer. It will spit out 2 to 10 sheets of blank paper when printing from the internet. It might print 2 lines on the first page and the next two lines on the...
Hi there it may be the driver remove the printer driver then put it back in again it may work, an other thing is it the right driver for the windows you are using.
All The Best Pineworks
Feb 09, 2010 | Brother MFC-7220 All-In-One Laser Printer
How to turn off a mfc 7220
??? Press the black power button on the lower right hand side, towards the back -- or unplug it :)
Sep 25, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
"No paper Fed"
Check the paper cassette and make sure the paper stop is flush up against the paper if it's not push it up against the paper and try again to print.
Aug 11, 2009 | Brother MFC-7220 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
266 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
