Question about Kitchen Ranges
Whirlpool range oven will not start to heat on bake but, the glow plug is working. the broiler does work.
  • 139 Answers
Sounds like you need a new bake element or could be a burnnt wire at the element look at the element is it broken ?
Posted on Aug 22, 2010
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
The broiler works but the bake option doesn't work, the oven doesn't get hot, any suggestions?
Check the bake ignitor (glow bar attached to the burner). If it does not glow at all, but the voltage is supplied to it - replace. If it does glow, but draws current less than 3A - replace.
Oct 14, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Dec 12, 2006 | GE JGBP26 Gas Kitchen Range
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
