Question about RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke
Pocket bike starts with starting fluid but then even after its warm it wont start on its own, and when its running the idol is higher with the choke on, the bike almost wants to take off, if I turn the choke off it idles ok but only for a minuet then stalls. Any feedback would be appreciated.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Did u put oil on the air filter? if thats ok then it sounds like you have a clogged pilot jet in the carb, pull the float bowl and remove jets then poke thru with fine wires untill clean. also take note of air mixture screw which will be located around the opening of the carb. clockwise will richen it up and start to make the idle drop and counter clockwise will do the opposite.
Posted on Aug 20, 2010
After start it backfires, sputters then runs
Hi,when starting bike you put the chock on,remeber this is to make a richer mixture for cold start,so when you start the bike put put the choke off a little bit as it warms up,other wise wat you are doing is couseing it to floud,so again as the bike warms up put the choke off little bit at a time,all the best.
Sep 01, 2015 | Honda VT 1100 C2 Shadow Sabre Motorcycles
Cagillari pocket bike starts but won't stay on
usually a carburetor problem, bad gas, fuel filter clogged or CHOKE needs to be turned lower soon after starting - move the choke toward "run" slowly until it is warmed up.
Aug 28, 2014 | Motorcycles
Honda Hornet wont start
I am having trouble with your english translation of the symptom. However, if your bike starts and runs fine once it is warmed up and initially starts fine in warm weather this indicates a clogged choke circuit in the carburator and will require a thourough and proper cleaning of the carb.
Dec 30, 2012 | Honda Hornet 250 Motorcycles
My 1993 suzuki gsf 400 bandit will only start if i spray starter fluid into the intake on the breather or if i jump it off !
The carburetor choke circuit is probably plugged up. Remove the carbs and thoroughly clean them making sure that the choke orifice are especially opened.
Nov 16, 2012 | Suzuki Motorcycles
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My cbr 600 f2 1993 had been sitting for a long time
Sounds like the carbs were not properly cleaned or set up. Choke should cause the cold start rpms to be higher than what you are experiencing. Application of choke to a warmed up engine will usually cause the engine to stall.
Jun 28, 2010 | 1994 Honda CBR 600 F(2)R
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
1984 aspencade starts w/choke and revs up, runs smooth. Take off
My 'wing won't run unless it has been warmed up some. I would suggest that you r&r your carbs to make sure the jets in the bottom are working correctly. They tend to get plugged up, especially after sitting & the aluminum flaking off inside... Rick
Apr 05, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
DR 200 runs really cold. Takes about 15 minutes or so to warm up
It depends on the tempature, if its pretty chilly out yeah. Try easing the choke in slowly, and when it will idle at about half choke go aheand and take off but run the bike easy for a few minutes then close the choke.
Mar 29, 2009 | 2003 Suzuki DR 200 SE
Bike will not start not getting any gas
you need to check your choke prob not a choike issue just you have it open or its stuck but it sounds like a easy fix
Mar 17, 2009 | 1995 kawasaki ZX-6R Ninja
RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke Logo
751 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
