Question about Kenmore Dryers
Dryer doesn't start ... changed start button and bird.... fuse good.. door light comes on...
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 20, 2010
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
I have a Kenmore 90 series dryer, and I have power to the 220/240 plug then when I open the door the light doesn't come on or the dryer doesn't run. I'm not sure where to look next, I don't...
Make sure both sides of the receptacle has 110 volts. Take meter and keep prong in ground slot and then put red prong in the others. You should have 110 volts in each one. If not change receptacle.
Sep 11, 2017 | Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
My dryer wont start pushed control on button but no lights will come however i do have a light inside the dryer this is a whirlpool 9250
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 14, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
