Question about Sunpentown SPT IM-100 Portable Ice Maker, for up to 2.5 lbs of Ice
PC board replacement for ice maker - Sunpentown SPT IM-100 Portable Ice Maker, for up to 2.5 lbs of Ice
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My Maytag M1TXEMMWWB00 (209 cu ft) Top Freezer Refrigerator will not make ice. I checked the solenoid where the water comes in to see if it has a current and it doesn't (no juice). I looked at the owners...
The ice maker tells the water valve to open so you will not see the power until the ice maker ask for water. Does the ice maker have ice remaining in the ice slots? If not then fill with tap water and after the water freezes and ice maker cycles dropping the ice into the ice bin if it does not refill with water then you will only need to change the=> 2315576 Water Inlet Valve If the ice maker does nothing you will need to change the ice maker=> 4317943 Ice Maker Assembly You can find trouble shooting info at Appliance 911
, Thanks John Tripp
Feb 19, 2014 | Maytag M1TXEMMWW (209 cu ft) Top Freezer...
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
Nov 03, 2012 | Refrigerators
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not making ice
Fill the ice maker with a cup of water manually. If it doesnt make ice the next day then replace the ice maker. if it does replace the solenoid after you have check that you have water going to the valve (good hard pressure) and the tube behind the frig that feed the water to the icemaker is not blocked with frozen water.
Mar 27, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Ice maker is not getting water to make ice
The most likely cause is the green water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control. You can buy the P. C. boards and a new water inlet valve kit with new quick connections at www.repairclinic.com or www.appliancepartspros.com Both sites are very helpful and most likely have these parts in stock.
Dec 26, 2008 | Whirlpool GD5SHAX Side by Side...
Sunpentown SPT IM-100 Portable Ice Maker, for up to 2.5 lbs of Ice Logo
41 people viewed this question
Top Sunpentown Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
matt
matt
Are you a Sunpentown Kitchen Appliances - Other Expert? Answer questions, earn points and help others
