Question about GE Dishwashers
My dishwasher is displaying an C2 error code, I can I fix this
3 Suggested Answers
  • 9 Answers
SOURCE: Jenn-Air dishwasher: error code C2 and C1
This is not a JDB6510 Model. Check the inside label when you open the door.
Posted on Nov 20, 2008
  • 668 Answers
SOURCE: Error code C2 showing on my Oko Favorit
Error Code C2 means drain line totally blocked.
Check drain valve for restriction in pump, check drain line. When there is no problem in drain line then check for a bad float switch or a bad control board . You will get this error even when there is no water in the tub . You can check the float switch with an ohmmeter. It should be open if the float is up and closed with the float down.
Hope this helps .
Thanks for using FIxya.
Posted on Dec 13, 2009
I have a oko favorit 4071 doesnt start and display H8 error.
I think this is not the error code. I belive this is hardness of water (could be set from 0 or 1 to 10, depending of model. Read your user manual how to exit the program for adjust the water hardness).
Error code for your appliance depending on model and look like:
i10, i20,i30............ or
C1, C2,C3.............
Dado
Jul 06, 2015 | AEG Dishwashers
How to fix a c2 error message on an aeg dishwasher?
C2 error may indicate a pump problem or too slow pump action this may be due to a blockage in the pump or a failed or failing pump capacitor this is not an expensive fix look for a replacement capacitor on Maplins of uk white goods web site you can get the size from the details on printed on the capacitor.
Apr 24, 2015 | AEG Dishwashers
AEG dishwasher C2 error
Dear Sir:
Please read the instruction manual for to fix this error.
If you do not have go for free download: www. fitness.manualsonline.com or www. retrevo.com
see the wiring diagram for help.
May 07, 2012 | Dishwashers
The dishwasher displays "A 1"
Hi - you should obtain the services of a certified electrolux serviceman to help you. The problem is you have no water flow into the machine, could be a number of things assuming the water has been turned on....
Inlet solenoid is faulty
Filter clogged?
Is the overflow insid ethe wash tank in place?
Pressure switchs on the boiler and tank working?
May have to reprogarm a new main board if this one is faulty - which could be the case.
I do actually service these as part of my job - but the components are specialy made for these and they ain't cheap - I think you are aware of that.
In most cases if the coil is fauty on the inlet you can retrofit another as long as is similar in design and voltage ..
BUT BE CAREFUL - YOU FIX AT YOUR RISK - WILL NOT BE ACCOUNTABLE FOR YOUR ACTIONS.
Cheers
Jun 20, 2011 | Electrolux 504199 Dishwasher
Error code C2 showing on my Oko Favorit dishwasher. What does this mean?
Hope this helps .
Dec 13, 2009 | Dishwashers
Code: C 2 ??
C2 error code means, that the drain is clutched.
Removed all dishwasher water with a cup.
Added a gallon of boiled water, waited 10 min and it worked again( so far).
Regards
Sigurd
Jan 28, 2009 | AEG 24 in. Favorit 80800 Free-standing...
Sep 09, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Norcold fridge displaying error code c2
My refer was displaying error code C2...I troubleshot it and found that C2= "no 120 VAC" coming off the board for heaters. Heaters were good (checked out with Ohm meter) so it had to be on the board. Turned out to be easy...about only parts on the board that could cause this problem was a S.P.S.T. relay...purchased from Digi-key for $1.70...beats the price of a new board nearly $500. Been working fine now for about 2 weeks.
Aug 23, 2008 | Refrigerators
Electrolux WT-4 -- C2 error code -- What is it?
C2 is Boiler temp too high.
Possible causes include:
Boiler Temp setpoint adjusted above 90C in programming
Boiler relay welded/melted
Boiler water level sensor not functioning correctly
Hope this helps,
Kermit
Aug 20, 2008 | Electrolux Dishwashers
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Dishwashers Logo
50 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
