Question about Garden
I have a sears Craftsman 5hp air compressor with 20 gallon tank. It runs for a while and then will slow down and stop. It won't run again for quite a while. Not sure if it's overheating or if it thinks it's over heating. Can anyone help? Thanks, Brian
  • 2 more comments
  • Brian Lester Aug 20, 2010
    Hi Clay and thanks for your response.
    I believe my compressor is not the oil type. Any suggestions in this case?
    Thanks again.
    Brian
  • Brian Lester Aug 21, 2010
    Hi again.
    Model # 919.165250
    I went to sears website to look at a parts list but when I punched in this model # , it came back with model # not recognized. The label on the compressor is clear with that #.
    I am going out of town until Monday afternoon, so if I don't respond until then, you'll know why.
    I checked the little air filter and it looked clean.
    Thank again for your help.
    Brian
    Thanks Mike.
    I get it.
    Unit is electric. No extension cord. I think I have it set to stop at 80 to 100 lbs
    It stops when it gets to that pressure. But when I demand more the motor will eventually slow down and hum and if I don't turn it off, I'm sure it will blow a breaker.
    I will be out of town the the next few days.
    Thanks for your help.
    Brian
    Thanks Clay.
    It definitely builds pressure ok for a while and shuts off when it reaches my set pressure level.
    It's just that if I keep running it for very long it will slow down and hum and then I shut it off.
    Thanks again.
    Brian
  • 1,498 Answers
Hi There,
I'm going to need more info. First I'll give you a couple of things to try. If they work, great. If not. we'll see about getting me some detail (listed below). If you can't supply the detail, I'll pass on attempting to answer.
My first question would have been Gas or electric? I'm going to assume electric..
Is there an extension cord between the compressor and the wall?
Does it get warm to the touch? If yes, try a thicker (lower gauge) or shorter one.
Does it blow fuses/trip breakers?
Try running it on a different circuit.
When was the last time you drained the storage tank of water?
Ever? Is the unit 'Very Heavy'?
Release the pressure first. There should be some heavy bolt on the underside. Double check the pressure is zero. Open and empty the water. Plug the hole.
Run it. when it starts to bog, note the pressure, listen close to the motor. When it stops spinning, is there a click or a continued hum?
Before it starts again, is there another click?
If so, that's it overload / over heat resetting itself
I hope something above works for you, that way you can avoid the waves of additional info necessary.
Off the top.
Does the motor have a reset switch?
Is it the original motor?
Model ?
Units normal maximum pressure, the point at which it should turn off.
Units minimum pressure, the engine will start at this point or lower.
The point at which it currently bogs down and stalls.
Details.
Often, a problem can be the result of a seemingly unrelated event. It is always a good idea to include a recent history.
Additional information such as what steps have already been taken, has the product ever worked, is it new, etc. can have a bearing on providing the best solution for your particular circumstances.
Remember, you are a key participant in this process. We are not there, you are. We depend on you to be our eyes and ears. We can only respond to what you provide us. Without you, all our talent is worthless. How's that for an ego build?
What you get out of the experience depends on what you put in to it. So help us help you.
Posted on Aug 21, 2010
  • 2,841 Answers
Sounds like the thermal breaker is tripping on the motor. If it is an oil lube compressor then change the oil in the compressor. Be sure and use exactly the correct weight an viscosity oil as listed in your owner's manual and do not overfill it, which can be as bad as under-filling. It may or may not use non-detergnet oil so be sure. I would recommend synthetic oil. Release all air from the tank and drain it to remove any moisture. Clean all dust and debris from the compressor cooling fins. Use the air hose to blow all dust from the electric motor. Also do not use an extension cord with this compressor as it will cause the motor to overheat. Also make sure the circuit the compressor is using is not overloaded.
Posted on Aug 20, 2010
  • NOT ME Aug 21, 2010
    Hey Brian, What Model is your Craftsman air compressor? I need to look at the specifications on the unit. I forgot to mention that you need to check the inlet air filter and make sure it is clean oilless or oil filled. A dirty filter will cause either one to overheat. Once I know the model you have I may be able to help more.
    A few things. First off you indeed have an oilless compressor. Is it building pressure. If not then it will continue to run until it overheats. If it is not building pressure then the Pressure Switch, compression rings (2), or head gasket is bad. Not the Pressure Regulator but the Pressure Switch. If you notice it leaking air at the unloader then the pressure switch is definitely defective. If it builds pressure then these are not the problem. Look at the fan and make sure no fan blades are missing and the cooling fan is working properly. Remove the cover and clean it up and make sure all is well. On this link you will find a diagram of your unit and a parts breakdown.
    http://www.mastertoolrepair.com/sears-cr...
    Another possibility is the motor is having problems. Turn on a light that is on the same electrical circuit as the compressor. Now turn on the compressor and watch that light. If you see the light dim then the motor is working very hard. It can be the start capacitor in the motor or the windings which would require the motor to be replaced. If it is just the start capacitor then replacing that will solve the problem. And lastly if you have too big a load on this circuit as in a refrigerator in your garage running on the same circuit at the same time as the compressor it will cause problems as the circuit will be not necessarily be overloaded but be creating a situation where the circuit is maxed out. This is all I can think of that will cause what you describe.
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
1988 20 gallon 5hp sears air compressor leaking quite a bit of oil. Can it and is it worth repairing?
I would think that is is actually coming from the crankshaft seal and running down. Does it leak when you are not using it, or just when it is being used? If it leaks even when it is not being used then it could be the drain plug. If it only leaks when being used then I would look at the crankshaft seal. And yes it would be very feasable to repair it, because like all things they don't make them like they used to.
Apr 23, 2012 | Craftsman 33 gal Air Compressor 6 hp...
What type of oil to add
Mobile synthetic 10-30 , Craftsman compressor oil if K-mart or Sears are near by. You can also use a non-detergent 10 - 30 motor oil , I use Mobile or Craftsman in mine. I have three - one is a Campbell Hausfeld this oil is per their book - (minus the Craftsman)
Don F
Sep 08, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
Aug 02, 2010 | Craftsman Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Air compressor w/5hp motor
Assuming that the motor is factory matched to pump, it should be powerful enough to turn the pump. Most problems with motors are related to pressure switch and/or capacitor. The pressure switch could have burned contacts causing low amps to reach the motor. The capacitor should test at least 90% of rated value printed on capacitor. Some volt meters have capacitor check setting. Also this motor at 5 hp must draw lots of amps. The outlet should be rated at least 20 amps and plug the compressor directly into oulet without an extension cord. \
Secondary problem is the in-tank check valve. The check valve should hold in tank pressure without leaking back to the head of the pump. If check valve leaks, replace it with any brand of same thread size. enjoy
Oct 29, 2008 | Air Tools & Compressors
Garden Logo
570 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
