Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can I port forward 554 and 8080 in this modem?
    Problem Solver:
  • 5 Answers
Check in the manual if you have it, if not check in google with the model of the modem for it's capacities in the modem specs.
Posted on Aug 21, 2010
Port forwarding
Connect your Internet phone directly to the cable modem and see if you can use Internet phone directly through the modem.
If it works through the modem then it must be the issue with the port forwarding.
First get the port numbers from the phone manufacturer.
Open the setup page of the router and open those port numbers.
Jan 15, 2012 | Linksys Wireless-G WRT54G Router
How do i accomplish port forwarding on a motorola sb5101
motorola sb5101 is a modem. Modems don't offer any settings to change. you would have to forward ports on your router if you have one. Other wise you will have to open the ports through your current firewall.
Jul 18, 2010 | Arris SURFboard SB5101 Cable Modem
Router portforwarding
Use the below website to configure your port forwarding
http://portforward.com/
Choose your modem type and application that u want to do port forwarding..
Aug 18, 2009 | Cisco CAB-OCTAL-MODEM (CABOCTALMODEMBXF)
Port Forward on Comcast Motorola SB5120
Are you just using a modem and NO router? This modem has no NAT so there is no way to open ports.
Jul 09, 2009 | Arris SURFboard SB5120 Modem
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Port Forwarding
I found siemens sl2_141 on www.portforward.com but not sl1_141.
Click here
Apr 07, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Port Forwarding with BR-6104K
hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual: http://www.edimax.com/images/Image/manual/Wire/BR-6104K/BR-6104K_M.pdf
instruction site
http://portforward.com/english/routers/port_forwarding/Edimax/BR-6104K/ICUII.htm
to test the port connection you can go to http://whatsmyip.org on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
Port Forward a RCA Thomson DCM305R
it just a cable modem. I don't think it does have firewall. It won't block anything.
- Laxman
Nov 22, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Port Forwarding
there is a way for you to port forward to anything that you would want, the only thing that you would need is the port numbers in order for this to work. Using terms.
1.) In your address bar, type in, "192.168.0.1". And by default, your username should be blank, and your password is, "admin".
2.) Once onto the mainpage, look up at the top of the page, and go into advance.
3.) And then look on the left hand side, and click into a tab that says, "Forwarding".
4.) Fill in you information/chart.
a.) Easiest way to find your ip address is to go to, "Start"(bottom left of your screen), click "Run", and then type in, "ipconfig/all".
b.) Enter in your Start and Exits ports like I said in the beginning.
c.) TPC/USP
d.) And then click "Enable" box, and click, "Apply" at the bottom, and your done!
Jul 27, 2007 | RCA Cable Modem DCM315R (11603540)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
167 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
