Question about Kenmore 24.8 cu. ft. Trio French Door Bottom Freezer Refrigerator
Temperature in refrigerator compartment is slowily going up. Freezer is OK. Doors are closed properly
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
GE S-Series Side-by-side refrigerator
you ll change the temperature control unit,since its not performing optimally
.thanks and godbless
Sep 29, 2008 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
Refrigerator side not cooling but freezer works
hi there,
first check is anything is blocking the refrigerator door from being closed properly.
Then see if the temperature is set correctly.
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
Jun 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer FZ175 Red Warning Light is flashing
The flashing red light indicates the problem in the temperature of the unit.The temperature is rising over then required so the red light is flashing. There are some possibilities that you will have to get checked.
1) Make sure your freezer/refrigerator door is closing properly and sealing all around.If the doors are not closing properly then this can lead to rise in temperature.
2) If doors are proper and closed properly then other possibility is to check the compressor .Check the compressor is it running properly or its not running.Beside the compressor there is a fan if the fan is running the compressor is turning on if fan is not running the compressor is not running.If the unit is not getting very cold this also indicates the problem is in the compressor section.A weak or faulty compressor causes the temperature rise problem.
3) If compressor also checks out ok then the other possibility is fault in the thermostat of the unit.The thermostat is getting overheated and this is causing the red light flashing.
4) Before replacing any part in the unit try the defrost procedure first .Keep the unit unplugged from power and keep both the freezer/refrigerator doors open .let it remain unplugged for 24 hours.Then reconnect the power and check for some time.If the unit works properly that means defrost procedure solved the problem.But if same error light comes On flashing that means the faulty part needs replacement.
You can get required parts for your refrigerator from the on-line sites like :--
www.partsselect.com.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 04, 2010 | Refrigerators
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Refrigerators Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
