Question about Tecumseh Enduro Horizontal Engine 5 HP 2532in x 2 2532in Tapered Sha
The engine will start but it will not stay running. I took the bowl out to clean it and now it won't start at all.
  • 45 Answers
Well you have to clean all of the carb not just the bowl and on some engines the screw at bottom of bowl is a fuel screw
Posted on Sep 09, 2010
Huaya carb no gas in bowl
the needle has to fall down and follow the float movement
if it doesn't it is stuck on the seat and may need replacing as it has a small rubber section that may damage when pulled down
Apr 24, 2017 | Cub Cadet Electrical Supplies
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Hi, I have a Craftsman Eager-1 5.3 3-in-0ne solid state enigine lawn mower..got it used but in almost new condition. worked great cutting 1 1/2 ft of very wet grass for a few hours (couldn't get to it...
Drain the fuel or when you remove the float bowl bolt (also the main jet), then hold up on the float to keep the needle on the seat so gas won't go everywhere. When you have that brass bowl bolt off, clean it! Use nothing metal on it. Pay close attention to the small hole in the bottom and along the smooth unthreaded part at the other end. Use carb/choke cleaner to blast gum and dirt out of those very small fuel orifices. I recommend installing an inline fuel filter also. A shut off valve is recommended too, that way if the needle in the carb sticks open, the crankcase won't be polluted with gas. Usual symptoms on a clogged lawn mower main jet though, are after pushing primer bulb, engine runs about 3 seconds. Try the brass bolt cleaning and post back if needed.
Jun 14, 2011 | Garden
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
2004 Honda CRF 150 F won't stay running
Hi, Smiley1961 and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
more help with the 150r please won stay running
Brand new CRF150 won stay running
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 09, 2010 | 2004 Honda CRF 150 F
Yard machine rider won't stay running
sound like you have some water in the engine, try removing the spark plug and squirting a little water repellent like wd40 or duck oil, crank it over a couple of turns, make sure the plug lead is away from the plug hole, then squirt some damp start in and refit the plug and try again.
May 02, 2009 | Garden
Snowblower wow's
tecumseh snow engines are natorious for not starting,first thing you need to do is take the old gas from the tank.gas only stays good for about 30 days.YEP .....that's all.there should be two screws that holds the cover over the carb.take the bowl off and there should be water and dirt in the bowl.clean that out,be careful not to drop the needle off the float.if you do it take a little patence to put it back on.now the nut you took off the bowl has three holes in the side of it.clean all the holes,one is really small and it's up twards the theads..replace the bowl gasket and reassemble the carb.now you should have fuel to the cylinder and it should start.if not let me know
Mar 02, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Enduro Horizontal Engine  5 HP 2532in x 2 2532in Tapered Sha Logo
367 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
